When you ask those managing artificial intelligence (AI) initiatives in the manufacturing sector how their pilot projects are going, you often hear a similar story: The proof of concept (PoC) was successful, the demo impressed management, and the budget was approved.
However, somewhere between that moment and deployment into a real production environment, things stall. The tool is used by a few people for a few months, and then quietly disappears. The problem it was supposed to solve is still there.
βββββββββββββββββββββββββ
π Not a Technology Problem, but an Implementation Problem!
This is not a technology problem. Industrial AI has truly advanced. Computer vision systems that catch defects missed by human inspectors, models that can predict equipment behavior weeks in advance, optimization tools that deliver efficiency in processes that have operated the same way for decades... This technology works.
What doesn't work consistently and cost-effectively is everything surrounding the technology. I've deployed AI systems in manufacturing environments across multiple facilities and industries for years. The patterns of failure are surprisingly consistent.
Here are the five most common mistakes:
β 1. Choosing the Wrong Problem
Use cases are chosen because they are technically interesting, because a vendor demo looked impressive, or because a competitor announced something similar. Not because there is a real operational problem and AI is the right tool to solve it.
[]A food and beverage company spent eight months building a demand forecasting model for a product line that its sales team already accurately forecasted with a spreadsheet.
[]An automotive supplier deployed an AI scheduling tool at a plant where the factory supervisor had been doing it manually for 12 years and getting better results.
In one version of this, AI still wins even if human work does it well enough: If the model catches human accuracy, the human is freed up for higher-value work. This is legitimate.
But this must be the stated business justification from the beginning of the project and accepted by the people whose jobs are changing. It cannot be something the team finds afterward to justify an already struggling project.
π 2. Not Measuring the Situation Before the Project Starts
If you don't record where you started, you can never prove you've made progress. This is consistently overlooked. Teams get so focused on building the model that no one writes down the baseline: what was the defect rate, how long did the manual process take, how many hours were lost the previous year.
Six months later, someone from finance asks if the project is delivering value. Without a baseline, the only honest answer is that you don't know.
I've seen really good AI deployments get shut down, not because they failed, but because no one had the numbers to show they worked. Solution: Agree on three metrics before the pilot project starts, write them down, and track them. This conversation takes an hour. It might be what keeps the project alive.
βοΈ 3. Not Connecting the Output to How Work Is Done
Teams build AI systems and leave them alongside existing workflows, rather than integrating them. The quality team still logs defects in the same spreadsheet. The production supervisor still makes scheduling decisions from the same weekly report. The AI output sits on a separate dashboard that someone has to remember to check.
No one remembers to check. The tools that get used are the ones where the AI output triggers something in a system people open every day. If a quality AI flags a defect pattern and automatically creates a ticket in the quality management system, someone acts. If it sends a notification to a standalone dashboard, the notification is ignored.
This isn't a technology integration problem. This is a workflow design problem that needs to be solved before, not after, deployment.
π€ 4. Executive Sponsor Departs
Almost every AI pilot project gets approved because a senior executive believes in it. This person attends the demo, approves the budget, and discusses it in leadership meetings. Then they get pulled into something else, move to a different role, or lose patience when results come slower than expected.
When this happens, the project loses its support. Integration work requiring cross-functional collaboration stalls. Budget renewals are questioned. The team keeps the system running, but it never gets the organizational support needed to scale.
A single sponsor is not enough. You need at least two leaders who understand what the project is trying to do and who will still be there 12 months from now. Also, the business justification needs to be well-documented enough that it can be explained even without them in the room.
β³ 5. The Pilot Project Lasts Forever and No Decision Is Made
The pilot project shows some promise, but not enough clarity to move to full deployment. So instead of making a decision, the team keeps it running. Six months becomes nine months. Nine months becomes 12 months. The data science team is stuck maintaining something that is neither working nor failing. The business doesn't get the value of a real deployment.
Every pilot project should have a decision date written into the plan before it starts. By this date, based on these metrics, we either scale or stop. If the metrics aren't there, you either extend with a clear explanation of what still needs to be proven, or you stop. What you don't do is let it drift. Drifting is how good technology dies without anyone wanting to kill it.
π Common Denominator: Organizational Problems
None of these are data science problems. A team can build a perfect model and fail at every one of these. These are organizational problems: strategy, measurement, workflow design, leadership continuity, and decision-making. Companies that get this right approach these problems with the same rigor they apply to the technology itself.
The question to ask before any AI investment in manufacturing is not whether the model will work. The real question is whether the organization around it is ready to act on what the model says. That question is harder to answer, but far more important.
