🤔 Looking to Modernize Your Facility?
While the idea of modernizing your facility is appealing, the word "downtime" often halts plans. Lost production, missed targets, and difficult conversations... So, how do you achieve this without disrupting operations?
💡 No Silver Bullet, But There Is a Solution!
No single technology magically eliminates downtime. The solution lies in a clear understanding of your current system.
🔍 Visibility First: Understand What You Have
Before touching any system, you need a complete picture of your environment. In most legacy facilities, this picture is far from clear. New equipment added over the years, older systems running longer than expected, and outdated documentation... The result: an environment that's a mix of PLCs, HMIs, patched integrations, and "tribal knowledge."
This is where a comprehensive IT/OT assessment comes in. This means physically opening control panels, cataloging hardware, and mapping everything to its lifecycle status. The goal is simple: understand what you have, what's at risk, and where the dependencies lie.
One of the biggest gaps often emerges in communication. Legacy systems relied on serial protocols, while modern environments rely on Ethernet to move data across the plant. This transition isn't just about connectivity; it's about making data usable. If you can't access it, you can't analyze it, and you can't progress to more advanced capabilities like analytics or AI.
In short: Without true visibility, you can't build a low-risk plan.
🏭 The Reality of Existing Plant Environments
If you're working in an existing facility, you already know this: nothing is simple. You're not starting from scratch. You're dealing with years, even decades, of incremental change. Multiple PLC platforms running side-by-side. Control logic that's been modified repeatedly. Systems not designed to work together, but now expected to.
That's why "rip and replace," while it looks good on paper, rarely works in practice. The risk is too high.
And most facilities don't even have the time window to attempt it. In some cases, you might be limited to a weekend, in others, hours, or even a single 12-14 hour window once a month.
This completely changes the equation.
Because while planned downtime is a concern, unplanned downtime is often a greater threat. Older systems don't just fail; they fail unpredictably. Spare parts can be hard to find. Recovery often requires bringing in resources at short notice, sometimes at significantly higher costs.
What could have been a planned upgrade turns into an emergency.
🌍 How Does This Look in the Real World?
This isn't theoretical. Teams are modernizing live production environments without shutting down production.
For example, a food processing plant dealing with over 30 years of layered systems. The plant operated with outdated PLC platforms, inconsistent control strategies, and limited documentation, meaning even small changes carried risk. At the same time, there was no real opportunity for extended downtime. Production schedules only allowed for short, tightly controlled windows, and missing them was not an option.
The key wasn't to jump straight into implementation; it was planning. And not just a quick planning exercise. This work began months in advance, often aligning with budgeting cycles, with teams addressing timing constraints, resource availability, and how new systems could be physically introduced without disrupting operations.
One of the initial challenges was determining how to segment the system so that upgrades could occur without impacting upstream and downstream processes. From there, the team built parallel environments to production, validating control logic, communication, and system behavior before going live.
Implementation followed a structured approach:
- Dividing the system into defined upgrade zones that could be isolated
- Placing new hardware and configurations alongside existing systems
- Pre-validating performance, not during the transition
- Executing changes within short, predefined windows tied to maintenance or shift changes
Even more complex tasks, like migrating legacy PLC logic and managing I/O cutovers, were handled incrementally. Systems transitioned step-by-step, ensuring continuity and minimizing risk at each stage.
And just as importantly, every transition included a rollback plan. If something didn't go as expected, the team could quickly revert without impacting production.
The result was not just a successful upgrade; it was a fully modernized control environment completed without interrupting production. Crucially, it reduced the plant's exposure to unplanned downtime and established a foundation for better visibility and future improvements.
🔄 A Different Way to Implement Modernization
If you want to avoid downtime, the approach has to change. It's not about big, disruptive overhauls. It's about controlled, methodical progress.
1. 🧩 Break It Down into Phases
Instead of doing everything at once, you tackle it piece by piece:
- One line at a time
- One subsystem at a time
- One upgrade at a time
Prioritization is driven by lifecycle risk, production impact, and throughput, not by estimates.
And this isn't done in isolation. Operators and maintenance teams often know exactly which systems are causing problems; they see it every day. Incorporating this input into planning helps ensure you're solving the right problems first.
2. 🛠️ Build and Test in Parallel
Most of the risks are eliminated here.
New systems are developed alongside live operations:
- Shadow systems mirroring production
- Offline validation of control logic and visualization layers
- Pre-tested configurations ready for deployment
When the cutover happens, you're not hoping it works; you already know it does.
3. ⏱️ Keep Transitions Short and Controlled
Instead of long shutdowns, upgrades happen in small, defined windows:
- Maintenance periods
- Shift changes
- Pre-planned events with rollback strategies
This is how you make steady progress without disrupting production.
📈 It's Not Just About Avoiding Downtime
Yes, the immediate goal is to keep production running. But this approach also improves overall performance.
You typically see:
- Fewer unplanned breakdowns
- Better visibility into operations through accessible data
- Lower maintenance costs associated with legacy hardware
- Improved integration between systems
And one of the biggest benefits is clarity around return on investment (ROI).
Because upgrades happen in phases, you can compare performance line-by-line between modernized and legacy systems. You're not estimating the impact; you're seeing it. And that makes justifying the next step much easier.
Standardization makes it scalable.
For organizations operating across multiple facilities, this approach becomes even more powerful when combined with standardization.
