Despite over a decade of investment, Industry 4.0 has created many success stories. Some factories operate with a level of visibility and coordination that would have been unimaginable just a few years ago. Machines are connected, data flows, and in some cases, artificial intelligence (AI) influences decisions.
However, these examples, while significant, do not represent the industry as a whole.
🌍 Global Status and Maturity
[]The World Economic Forum's Global Lighthouse Network has recognized 223 advanced manufacturing facilities as of January 2026. These factories demonstrate what is possible when technology, data, and operations are tightly integrated. However, they represent a small fraction of global manufacturing.
[]Major benchmarking studies, such as Acatech's Industry 4.0 Maturity Index and INCIT's Smart Industry Readiness Index, show that most manufacturers are still at the beginning of their journey. More importantly, this situation has not changed much over time.
This does not mean that companies are standing still. Many have launched pilot projects, installed new systems, and advanced their digital transformation efforts. However, these efforts have not fundamentally changed how most operations function. Progress has been made, but it has remained local rather than systemic.
As a result, the gap between what is technically possible and what is operationally achieved is widening. This becomes even more pronounced as AI enters the equation. AI can generate insights faster and at a larger scale, but in many environments, it is being incorporated into systems not designed to support it. Instead of accelerating transformation, it exposes the limitations of the current state.
🚧 The Real Constraint: Operational Functioning
It's easy to assume that the problem is a lack of technology. In reality, most manufacturers already have the tools they need. The problem is not what is available, but how it is used.
Digital transformation in the context of Industry 4.0 depends on three conditions, the complexity of which is often underestimated:
[]Access to contextualized data at the right time and in the right place: While data is abundant in most factories, it is rarely structured in an immediately actionable way. It is often fragmented across systems, delayed in its availability, or disconnected from the process context needed to interpret it. A signal without context does not reduce uncertainty; it shifts the burden of interpretation to the person receiving it.
[]Ensuring information reaches the right people in a usable format: Operators, supervisors, and engineers need different views of the same underlying reality. When data is centralized in tools that don't align with how work is done, or distributed across disconnected systems, people compensate. They rely on meetings, emails, and manual coordination to fill the gaps. The organization becomes dependent on effort rather than supported by systems.
- Evaluating the operating model: This is often the most critical, as many organizations try to layer new technology on top of existing ways of working. Roles remain unchanged, processes are extended rather than redesigned, and decision-making authority is often unclear. As a result, complexity increases without a corresponding improvement in performance.
You cannot transform an operation without changing how it works. And you cannot change how it works without redefining how people work, how decisions are made, and how systems support both.
💡 From Digital to Intelligent, From Pilots to Performance
A useful way to understand what needs to change is to focus on decision latency—the time it takes to act on a signal. Every factory operates on the same cycle: Something happens, it is noticed and interpreted, a decision is made, and action is taken. In high-performing environments, this cycle is tight and continuous. In most factories, it is extended and inconsistent.
Reducing this latency improves performance. This requires better analytics, as well as the alignment of data, systems, and people around the flow of decisions. It starts with treating data as operational infrastructure; it must be structured and connected to reflect how the factory works. It requires designing around end-to-end flows rather than individual applications, ensuring that information flows seamlessly from detection to decision to action. It also requires clarity on decision ownership, especially as more intelligence is embedded into systems.
This is where the transition from digital transformation to intelligence transformation becomes critical. Digital transformation laid the foundation, but it was never the destination. Intelligence transformation—embedding decision-making into systems and changing how work is done—uses this foundation to fundamentally reshape how operations perform in real time.
Many organizations are trying to make this leap without fully building the foundations. Intelligence layered on fragmented data and unclear operating models does not scale. It creates isolated pockets of capability rather than sustainable improvement.
The result is stalled progress and differentiation. Companies that do this right will accelerate because each improvement builds on the last. Those that don't will continue to invest without seeing proportional returns.
The way forward is not to do more, but to do things differently. It requires making the operation intelligible, ensuring data is available when it matters, and aligning the organization around faster, clearer decisions. When this happens, performance becomes a property of the system itself, no longer dependent on individual effort or isolated success. When this shift occurs, the advantage quietly accumulates over time, until the gap between leaders and laggards is measured not by technology, but by how the business actually works.
