## Compact and High-Performance Linear Actuators from Schaeffler
Schaeffler is offering more compact and powerful solutions in motion systems by adding the new EMA-50 and EMA-60 linear actuator models to its EWELLIX series. These actuators expand the high-performance series designed for dynamic loads between 1 and 2 tons.
### Electromechanical Actuators: Solutions Complementing Hydraulics
The EMA series offers energy-efficient, oil-free, and low-maintenance electromechanical actuators. With the new EMA-50 and EMA-60 models, electrification opportunities are increasing in sectors such as mobile machinery, construction equipment, plastics processing, and food production.
### High Power Density in a Compact Size
- EMA-50: 50 mm cross-section diameter
- EMA-60: 65 mm cross-section diameter
Both models stand out in space-constrained applications by providing high power density in limited spaces.
### Three Gear Ratios and Flexible Motor Integration
- Three different gear ratios for power and speed adjustment according to different application requirements
- Flexibility in motor selection thanks to adapters compatible with standard motors
- Easy integration with existing machines via resolver systems and braking solutions
### Application-Specific Performance Scaling
The EMA series offers performance options in the dynamic load range of 1 to 8 tons. This allows for the selection of the most suitable actuator for the application, while maintaining a balance between cost and performance.
### Future Developments
Schaeffler aims to provide higher linear speeds at lower gear ratios by working on geared belt drive options. These developments bring new solutions to simulator motion systems and other dynamic applications.
Schaeffler continues to offer compact, efficient, and flexible actuators that support electrification in industrial and mobile applications with the EMA-50 and EMA-60.
