🚀 Next Generation in Industrial Automation: Laser Distance Sensor with IO-Link!
🌟 Revolutionary Sensor from Micro-Epsilon​
Micro-Epsilon is bringing a breath of fresh air to the world of industrial automation! The IO-Link integrated version of the optoNCDT ILR3800-100 laser distance sensor provides seamless compatibility with modern automation systems.
⚙️ Easy Integration and Automatic Maintenance with IO-Link​
Thanks to IO-Link, this sensor offers both a simple and cost-effective connection and communication compliant with the IEC 61131-9 standard. This allows the sensor to be quickly integrated into existing systems, significantly shortening the commissioning process. The best part is the ease of maintenance: when a sensor replacement is needed, the system automatically transfers the saved settings to the new device, minimizing downtime.
⚡️ Enhanced Performance and Dynamic Measurement​
The latest firmware update released for the ILR3800 series further enhances the sensor's performance. The integrated automatic correction feature filters out outliers and deviations, ensuring continuously stable and precise measurement values. The "DYNAMIC" preset, specifically developed for dynamic measurements, reacts quickly to sudden distance changes, accurately capturing rapid movements.
💪 Robust Design and Wide Measurement Range​
The new IO-Link version retains all the advantages of the standard model: a lightweight design, high signal stability on different surfaces, and a robust structure resistant to industrial environments thanks to its IP67 protection class. Its compact housing offers a measurement range of up to 100 meters in standard operation, which can be extended to 150 meters with an additional reflector. All data is reliably transmitted via the IO-Link communication standard. This sensor combines high precision with modern communication capabilities, opening up new possibilities in automated production and logistics processes.
📈 Standout Features in Competition​
Compared to similar products on the market, the ILR3800 series stands out, especially due to its high measurement speed and the new DYNAMIC preset. These features make it ideal for positioning in applications such as high-bay stackers, bridge cranes, and automated guided vehicles. While many competitors use expensive and specialized industrial Ethernet interfaces, IO-Link integration meets the demand for a cost-effective, fieldbus-independent point-to-point connection. This allows diagnostic data and parameters to be transferred up to the cloud level.
