## Nexen's Roller Pinion Systems Introduced at MACH 2026
Industrial Clutch Parts Limited showcased Nexen Group's advanced motion control components at the MACH 2026 exhibition, held from April 20-24 at the Birmingham NEC. The exhibition highlights industrial automation and precision motion control systems, focusing on high load capacity and precise positioning technologies.
### Roller Pinion and Rack System
Nexen's roller pinion and rack system is designed to provide high precision and load-carrying capacity in demanding applications. The system uses needle roller bearing-supported rollers to transmit motion, offering higher torque capacity compared to traditional gears.
One of its key advantages is zero backlash. Multiple rollers simultaneously contact opposing tooth surfaces, ensuring continuous engagement and eliminating the risk of positional play.
This structure enables:
- High positioning accuracy
- Stable motion under variable loads
- Consistent performance over long distances.
Additionally, the special tooth profile ensures smoother contact and load distribution between the gears, increasing the system's durability and operational stability.
### Performance for Demanding Industrial Applications
The roller pinion system is ideal for applications requiring precise linear motion in high-speed, long-travel, and complex geometry scenarios.
Example application areas:
- Automated production lines
- Material handling equipment
- Large-scale positioning systems
- Industrial machinery requiring repeatable precision
The zero-backlash design stands out as a critical feature for applications where product quality and system performance depend on positional accuracy.
### Engineering and System Integration
Nexen designs its motion control components for integration into a wide range of industrial systems. This roller pinion system allows engineers to easily adapt the configuration to operational requirements.
The system's ability to provide performance regardless of length or geometry increases its applicability in large or complex projects where conventional drive systems might be insufficient.
### Introduction and Technical Information at MACH 2026
At MACH 2026, Industrial Clutch Parts will showcase the system's features live and provide technical details on its integration into industrial automation environments.
This event offers engineers and system integrators an opportunity to evaluate motion control solutions designed with principles of precision, reliability, and scalability.
### Importance for Industry
With the advancement of industrial automation, the demand for high-performance motion systems is increasing. Technologies that combine precision, load capacity, and reliability are becoming increasingly important in applications where accuracy and uptime are critical.
Nexen's roller pinion system aims to improve motion control performance with innovative mechanical design solutions addressing these needs.
