High-Performance Solutions for the Mexican Water Sector with ABB's Vertical Hollow Shaft Motors
    ABB has expanded the availability of its industry-proven Vertical Hollow Shaft (VHS) motors to meet Mexico's increasing demands in the water sector. These motors, specifically designed for vertical pumping applications in critical areas such as agriculture, mining, municipal water services, wastewater treatment, and industrial processes, now come with NOM/ANCE certification.
    ### Importance of ABB Vertical Hollow Shaft Motors
    ABB VHS motors are supported by NOM and ANCE certifications, meeting Mexico's safety and energy efficiency standards. This allows equipment manufacturers and users to confidently implement ABB solutions in the country. Sam Harris, Vice President of Water Dynamics and Heavy Industrial Solutions at ABB, stated that these motors are designed not only for performance but also to provide a solution to Mexico's water crisis.
    ### Technical Advantages of ABB Vertical Hollow Shaft Motors
    • Easy maintenance: The top-mounted coupling design provides easier access to pump components, reducing service time and complexity.
    • Operator-friendly features: An integrated sight glass allows for quick visual inspection of thrust bearing lubrication.
    • High thrust capacity: Designed to handle vertical loads in deep well and high-capacity pumping systems.
    • Robust construction: Offers various enclosure options, such as weather-protected and totally enclosed.
    • Standard design: NEMA standard dimensions allow for easy adaptation to existing systems.
    ### Technical Specifications
    • NEMA Premium (IE3) efficiency
    • 175% extra thrust capacity on 440 frame motors and above
    • Inverter compatible, operates with variable speed drives
    • Heavy-duty cast iron frame
    • Power range: 15-500 horsepower
    • Multiple voltage and frame options
    ### About NOM and ANCE Certifications
    NOM refers to Mexico's mandatory technical standards implemented to improve quality in products, processes, and services. Products meeting these standards can use the official NOM seal. ANCE is a Mexico-based certification body that performs conformity assessment for electrical, electronic, and telecommunications products. ABB's VHS motors have strengthened their reliability in the Mexican market with these certifications.
    ABB Motion, as a global leader in motors and drives, continues to offer advanced technology products to industries with solutions focused on energy efficiency and sustainability. With over 140 years of experience and more than 22,000 employees worldwide, ABB is a pioneer in the sector.
