Fanless GPU Edge System for Multi-Camera AI
    ## Fanless GPU Edge System for Multi-Camera AI Applications
    Acceed GmbH has introduced a 19-inch rack platform that combines high-performance GPU acceleration and multi-camera connectivity with a fanless cooling system. This system brings together high processing power and reliable cooling for industrial edge computing applications.
    Industrial AI applications require high computational power directly at the point of data generation for image processing, quality control, and autonomous systems. Acceed's GT-92GC model offers CPU and GPU processing, multi-camera connectivity, and an industrial-standard passive cooling design in a fanless 19-inch rack format.
    ### Passive Cooling and Thermal Design
    Unlike traditional industrial PCs, the GT-92GC uses entirely fanless cooling. Heat pipes and an extended fin structure effectively dissipate heat from the CPU and GPU. This eliminates the risk of cooling fan failure, reduces mechanical wear, and minimizes maintenance requirements. The system is designed to maintain safe operating temperatures for the processors even under maximum load simultaneously.
    ### GT-92GC Technical Specifications
    • Processor support: Intel 12th to 14th generation CPU, LGA1700 socket
    • TDP options: 35 W or 65 W
    • GPU: NVIDIA RTX 2000 Ada, 70 W power consumption
    • Cooling: Fully passive, no fan usage
    • Operating temperature: -25 °C to +55 °C
    • Memory: Up to 64 GB DDR5 RAM
    • Storage: M.2 NVMe SSD (approx. 7 GB/s), two 2.5-inch SATA drive bays
    • Expansion: Two mPCIe slots, internal SIM card slot
    ### High-Density Camera Connectivity
    Multi-camera systems are critical in automated inspection, robotic guidance, and autonomous vehicle applications. The GT-92GC features 8 Gigabit Ethernet ports compliant with the IEEE 802.3at standard and PoE+ capability, allowing devices to be powered directly via Ethernet cable. With up to 100 W of total power provided, camera power issues are eliminated.
    Additionally, one Gigabit Ethernet port, four USB 3.2 Gen2 ports (10 Gbit/s), optional serial, CAN bus, and digital I/O interfaces are offered. This configuration allows for connecting up to 12 cameras via 8 Ethernet and 4 USB ports.
    ### Application Areas
    The GT-92GC is ideal for edge applications requiring GPU-accelerated AI inference, such as automated optical inspection, robotics, autonomous systems, and sensor data fusion. With fanless cooling and high processing capacity, it offers both thermal reliability and performance.
    Acceed GmbH, based in Düsseldorf, Germany, provides customer-specific configurations with industry-specific power supplies and connectivity accessories, backed by an ISO-certified quality management system.
