End Unnecessary Spending in Motion Control Systems: Mitsubishi MR-JET
    Mitsubishi Electric's MR-JET series offers ideal mid-range solutions for machines that fall between entry-level servo systems and high-performance, expensive systems. MR-JET provides reliable and powerful motion control performance while avoiding high costs and complexity.
    ### MR-JET Series Features
    • Designed as a mid-range servo drive and motor platform
    • Suitable for machines where entry-level systems are insufficient but high-end systems are unnecessary
    • Simplified wiring and flexible connection options for a wide range of applications
    • Easy integration into modern automation systems with CC-Link IE TSN® and EtherCAT® support
    • Ideal for packaging, converting, printing, tooling, material handling, and general manufacturing
    ### Precision and Performance
    • Prevents position deviations during acceleration and deceleration with superior tracking control
    • Reduces reaction delays dependent on the direction of motion with feedforward control
    • Minimizes excessive deviation and increases path accuracy with the path tracking function
    ### Compact and Clean Design
    • Compact amplifier with top and bottom mounting separating power and signal cables
    • Reduces panel width with side-by-side mounting capability
    • Optimizes machine layout with short motor length and low connector height
    • Provides power, encoder, and brake connection with a single cable, simplifying installation and reducing errors
    • Long-term maintenance convenience thanks to battery-less encoders
    ### Flexible Connection Options
    • Time-synchronized Ethernet motion at 1 Gbps (CC-Link IE TSN®)
    • Communication cycles up to 125 microseconds with EtherCAT® support
    • New HK series compact rotary motors with 24-bit battery-less ABS encoder and single-cable design
    • Linear motor options up to 6.5 m/s speed
    ### Ease of Use and Quick Start
    • Achieves stable motion in 0.3 seconds after servo power-on
    • Automatic gain optimization (One-Touch Tuning) requiring no manual adjustment
    • Smoother and more efficient motion with vibration suppression technology up to 1 Hz
    • Built-in position table allows PLC or GOT control, eliminating the need for an additional motion control device
    Mitsubishi Electric MELSERVO-JET offers a powerful alternative for those seeking cost-effective, compact, and high-performance motion control in modern machine designs.
