Bosch Rexroth's Next-Generation Conveyor System for Heavy Loads Up to 3000 kg
    Bosch Rexroth introduced the TS 7plus transfer system, which enables the transport of heavy loads up to 3000 kg. This fully electric and freely configurable system responds to the increasing heavy load transport needs in the automotive, battery, and defense/aerospace industries.
    ### TS 7plus Transfer System Features
    • Workpiece transport capacity up to 3000 kg
    • Modular, freely configurable transport sections
    • Ergonomic advantage with a minimum transport height of 350 mm
    • Maximum pallet dimensions: 2200 x 3000 mm
    • Solid and hollow conveyor rollers, 50% larger than the previous model
    • High availability due to fewer moving parts
    • Fast assembly and easy maintenance with an innovative bearing block design
    ### Lubrication-Free King Shaft Drive
    • Alternative to chain drives, lubrication-free king shaft mechanism
    • Motor torque is transferred to the rollers via bevel gears that do not contaminate workpieces
    • Gears do not require maintenance or re-tensioning
    ### Energy Efficiency and Operation
    • Holding at defined stops with stop gates
    • Motors operate only when needed, reducing energy consumption and maintenance costs
    • 180 W and 250 W motor options and third-party motor support interface
    ### Speed and Design
    • Maximum transport speed: 24 m/min
    • Motors can be mounted on the inner or outer side of the section
    • Inner motor placement prevents obstruction in the working area
    ### Software Support
    • Easy system configuration with MTpro planning software
    • Local installation and web-based version options
    • Automatic CAD model and parts list generation
    With this new generation conveyor solution, Bosch Rexroth makes the heavy load transport needs in production processes faster, more efficient, and more ergonomic. For product details, the company's booth can be visited at the Automate 2026 exhibition.
    ### About Bosch Rexroth
    As one of the world's leading companies in motion and control technologies, Bosch Rexroth offers efficient and safe solutions in mobile and industrial applications, as well as factory automation. The company, which reached a turnover of 6.5 billion euros in 2024, supports digitalization in the industry with IoT-compatible software and hardware integrations.
