Bosch Rexroth Expands Cartridge Valve Size Range
    Bosch Rexroth is expanding its LC-8X cartridge valve series, which reduces pressure losses and increases efficiency in high-flow hydraulic applications, with nominal sizes 80, 100, and 125. The new products will be introduced at the IFAT 2026 exhibition in Munich, Germany.
    ### High Flow Capacity
    • The new sizes support higher flow rates in hydraulic circuits for functions such as directional control and pressure control.
    • The valves are suitable for operating pressures up to 450 bar, allowing their use in heavy industry and water management applications.
    • The integrated shaft seal, standard within the valve, continuously maintains sealing integrity.
    • Durability for 10 million load cycles ensures suitability for long-term heavy-duty operations.
    ### Reduced Pressure Losses and Energy Savings
    • The LC-8X series reduces pressure loss with optimized flow geometry compared to previous models.
    • Less pressure loss means less heat generation and reduced cooling requirements in hydraulic circuits.
    • The friction-optimized piston design reduces internal leakage and energy loss.
    ### Standard Design and Backward Compatibility
    • The standardized architecture simplifies system integration and the engineering process.
    • Compatibility with previous models reduces the need for redesign in existing hydraulic systems.
    ### Material Efficiency and Sustainability
    • The valves are packaged in impact-resistant round containers made from recycled materials.
    • This practice supports an increase in resource utilization and an environmentally friendly approach while maintaining technical performance.
