Showcase Banner's HF RFID System Improves Industrial Tracking and Control
Banner has introduced a new line of HF RFID read/write heads and tags designed to improve short-range identification, matching, and traceability in industrial workflows. Operating at 13.56 MHz and supporting IO-Link and Modbus, the devices allow controllers to automatically read stored data without line of sight or manual input. Built for harsh environments, the IP67 units deliver reliable performance where barcode labels fail, helping manufacturers reduce errors, prevent mix-ups, and maintain cleaner process records.
Introducing Banner Engineering’s new HF RFID Read/Write Heads and Tags.
Banner’s new HF RFID read/write heads and tags operate at a frequency of 13.56 MHz with read ranges up to 110 millimeters. The devices also support both IO-Link and Modbus, providing engineers with a flexible way to bring short-range identification and traceability to existing control architectures. HF tags store small data sets, such as part numbers, tool offsets, cycle counts, or operator IDs, which remain with the asset throughout its journey across the facility. When the tag passes a read/write head, the controller automatically retrieves the information without the need for optical alignment or manual interaction.
What HF RFID Brings to Industrial Workflows
HF RFID can excel in applications where products pass through defined control points. Each tag carries its own data, so the system not only recognizes a code but also reads the last known status of the tool, part, or carrier. This enables two key functions: matching and traceability.
  • Matching verifies that the correct item or operator is present before a process begins, which helps prevent incorrect tool usage, misplaced parts, or unauthorized access.
  • Traceability creates a time-stamped record of every step, providing engineers with a clear view of how components move along a line.
This information can aid manufacturing industries by supporting audits, root cause analyses, and compliance, but it also helps optimize cycle planning and reduce scrap by revealing where deviations occur.
Designed for Real Industrial Environments
RFID equipment often fails when conditions such as vibration, debris, or moisture are present, so Banner designed the read/write heads with IP67 housings suitable for harsh manufacturing areas. The product line includes compact cylindrical and rectangular models that easily fit onto conveyors, machine frames, storage areas, or tool access points. The readers work with all HF RFID tags, whether embedded in metal, mounted on a tool, or attached to non-metallic surfaces, allowing facilities to combine existing tag inventories with Banner’s options.
With IO-Link or Modbus support, the readers communicate tag information directly to the control system, where it can be traced or tied into machine logic. This makes it easy to maintain accurate process data, even in noisy, dusty, or wet conditions. Because HF RFID is not dependent on line of sight, it provides consistent performance even where barcode labels degrade or cannot be reliably scanned.
CNC Tool Identification
For CNC systems, HF RFID provides a reliable way to link tool holders to stored setup data. Each tag holds identification and offset information that the machine automatically reads when the tool is loaded. This minimizes operator-dependent steps, prevents tool mix-ups, and maintains accurate tool life data across multiple machines.
RFID tags can be used to enable automatic identification and usage of tools within a CNC.
Short-range data capture plays a larger role in process reliability than most teams realize. When a system can consistently read and update information stored on each tag, it becomes easier to prevent mix-ups and track how assets move from station to station or across daily tasks. Banner’s HF RFID devices support this function by providing reliable reads in environments where barcodes or manual checks often fail.
