Rockwell Automation is automating controller code generation and system validation in the global manufacturing sector by integrating artificial intelligence with digital twin environments.
The company is introducing an AI-powered engineering framework that synchronizes digital twin simulations with controller engineering platforms. This reduces manual configuration processes in the automotive and heavy industry sectors.
### Digital Twin and Generative Programming Integration
In traditional industrial engineering, the disconnect between simulation and application stands out as a significant technical challenge. Engineers often use different environments for mechanical simulation and PLC development. Rockwell Automation addresses this problem by connecting Emulate3D digital twin software with FactoryTalk Design Studio and AI-powered interfaces.
This integration allows simulation parameters to be converted into executable controller code via a cloud-based environment. Using Large Language Models (LLMs) and autonomous agents, natural language inputs can be translated into structured text or ladder logic. This reduces time-consuming manual PLC configuration.
### Emulation with Closed-Loop Validation
The success of this model relies on a closed-loop validation process. AI-generated controller projects are tested on the digital twin before physical hardware is installed. This emulation phase ensures measurable validation of system logic, timing, and safety protocols.
According to Jordan Reynolds, Vice President of AI and Autonomy at Rockwell Automation, engineers can thus transition from a validated model to a fully tested controller project before hardware commissioning.
### Impacts on Industrial Efficiency and Safety
This method shortens engineering cycles while positively impacting the following technical KPIs:
- Reduced commissioning time: Virtual validation guarantees functionality before code reaches the factory floor.
- Improved design iteration: Engineers can refine factory models with natural language, reducing the need for manual recoding.
- Standardization: AI-driven code generation ensures compliance with corporate standards, increasing consistency across different teams and regions.
Furthermore, this framework supports worker safety and sustainability goals by optimizing machine movements and energy consumption during the simulation phase. This technology integration is considered a significant step towards autonomous industrial systems where the software layer plays a proactive role in the architectural setup of physical assets.
