🔥 A New Era in Critical Infrastructure Protection: High-Precision Thermal Cameras from Hanwha Vision! 🚀
    🔍 Hanwha Vision Redefines Security with AI-Powered Thermal Cameras!​
    Hanwha Vision is breaking new ground with its VGA AI Tele lens Thermal Camera series, designed for critical infrastructure and maritime security. These cameras combine AI with sub-16 millikelvin thermal sensors to precisely classify objects even in challenging environmental and marine conditions.
    🌡️ High Thermal Sensitivity and Intelligent Object Classification​
    The cameras offer a Noise Equivalent Temperature Difference (NETD) value of under 16mK. This ultra-sensitivity allows for the acquisition of subtle thermal data even when targets have temperatures very close to their surroundings. As a result, the AI engine can accurately identify people and vehicles, not just pixel movement. Even partially hidden or prone targets are detected, minimizing false alarms.
    🌊 AI Power in Maritime Surveillance​
    Beyond terrestrial security, the system features AI-powered ship detection capabilities optimized for marine environments. This enables automatic monitoring in areas such as coastal protection, port security, and maritime border control. Thanks to thermal technology, uninterrupted detection performance is provided even in fog, rain, snow, and complete darkness.
    🛠️ Hardware Configurations and Environmental Durability​
    The series offers four different fixed lens configurations: 13mm, 19mm, 35mm, and 60mm. This provides options for appropriate fields of view and detection distances for different areas. The cameras have IP66/67 and NEMA 4X ratings for dust and water ingress, as well as IK10 impact resistance. Their compliance with the MIL-STD-810H military standard proves their resistance to rain, humidity, vibration, and salt spray.
    🔒 Cryptographic Security and Data Protection​
    Each unit includes a Secure Element certified to FIPS 140-3 Level 3 standard. This provides protection against unauthorized network access and cyber threats through hardware-based encryption. SD card partition encryption ensures that recorded images are protected against tampering and data extraction.
    🎯 Unrivaled Thermal Resolution​
    While similar products on the market typically offer NETD values between 30mK and 50mK, Hanwha Vision's VGA series falls into an ultra-high sensitivity category with an NETD of under 16mK. This allows for the resolution of finer details in low-contrast scenes (such as dense fog or situations where target body temperature is close to ambient temperature), significantly increasing the operational range and accuracy of AI classification algorithms.
