🤖 The Success of Industrial Automation: It Starts with Understanding Operator Needs!
Elif Ă–zaksu
  • Altanlar
    Defining the Purpose of Automation​
    When evaluating whether automation simplifies an operator's job, we must first clarify the fundamental purpose of the automation. Is our goal to ensure more consistent quality, address a labor shortage, or simplify a specific task and reduce the operator's burden? These different needs should shape all our subsequent decisions.
    In-Depth Analysis of the Operation​
    If the goal is to reduce the operator's burden, we must examine the entire operation in detail. How repetitive is the work? Which movements require effort? Where does the operator have to make decisions? Understanding these details helps us pinpoint the exact point that needs to be automated.
    Looking Beyond Individual Movements​
    Let's illustrate with an example: In a processing line, an operator lifts a finished metal enclosure from an unloading tray, flips it, and places it into an inspection fixture. The proposed automation is a transfer mechanism between these two processes. The objective is clear: to reduce repetitive lifting while maintaining the enclosure's position and orientation.
    However, examining only this movement provides an incomplete picture. We must also understand how the component arrives, what happens when its position changes, and what the operator needs to do if the transfer stops. Otherwise, while eliminating one physical task, we might create another responsibility that makes the entire operation more difficult.
    Choosing the Form of Automation​
    Once the scope is understood, we can evaluate the form of automation. This could be a robotic solution, or a simple karakuri mechanism using counterweights or gravity. The choice should be a consequence of the operation and its requirements. Previous applications in relevant industries, supplier capabilities, and speed of implementation are also important.
    In countries like India, return on investment is a significant part of this evaluation. The cost of automation must be weighed against the intended benefits. If we are trying to reduce repetitive lifting, we must define how we will measure this reduction, along with quality and production requirements. However, defining the scope, selecting the supplier, and calculating the return is only part of the process. Understanding how the person on the shop floor will work with the automation is equally important.
    Making the Operator Part of the Change​
    In my experience, the sustainability of automation becomes challenging when operators change or begin to believe that the intervention will take away their jobs at the end. Even if the equipment remains, the work may revert to the manual method.
    Therefore, grassroots stakeholder management is crucial. The operator needs to understand why the change is being made, how it will benefit them, and what their responsibilities will be afterward. Their concerns should be discussed as the solution is developed.
    In our hypothetical example, the operator might be satisfied with the transfer during a demonstration, but might not know what to do if an enclosure arrives in the wrong position. If this concern is not addressed, reverting to manual handling might seem like a more reliable way to keep production going.
    Testing Under Real Working Conditions​
    A model line setup and trials help us understand these situations before scaling up the solution. This is where the plan-do-check-act cycle becomes important. Each of these four actions must be carefully addressed.
    • We plan the intervention based on the identified need.
    • We test it in operation.
    • We check the results with the people who use it.
    • We act on what we have learned, make corrections, and standardize the method when it yields the desired results.
    During the trial, allow the operator to run the sequence under normal production conditions. The trial should also include those who use the equipment on different shifts. Check with different enclosures and what happens when the transfer is interrupted. Can the operator follow the agreed-upon response, or does the work stop until someone else is called?
    Checking should also include whether the operator's job has truly been simplified. In the transfer example, we examine whether repetitive lifting has decreased, whether positioning remains consistent, and whether interruptions require additional handling. The operator must be part of this evaluation.
    Ultimately, the person working with the intervention must accept its benefit. Management approval alone cannot prove that the intended burden has been reduced.
    Sustaining the Improvement​
    Once the method is standardized, continuous monitoring is required to maintain its effectiveness. Operator changes should include training on the agreed-upon method and an explanation of its purpose. If usage declines, management needs to understand what has changed and address it with those on the shop floor.
    In my opinion, this brings us back to the most important question: Why are we automating this particular operation? When the goal is to simplify the operator's job, we must pursue this goal throughout the work, design, trials, and continuous use. Only then can we determine if the automation has achieved what we intended.
