🚀 Siemens Brings Industrial AI to Every Stage of Production
Siemens aims to integrate industrial artificial intelligence into different stages of automation. Solutions are offered across a wide spectrum, from AI agents in planning and engineering to physical AI on the production floor.
At SPS 2026, the company demonstrated how this approach enables goal-oriented automation: Manufacturers define what they want to achieve, and industrial AI determines how to reach the goal or executes the task through AI agents.
🏭 Autonomous Robot Application at Erlangen Electronics Plant
At Siemens' Erlangen Electronics Plant, an AI-based robot application is being developed for the autonomous unpacking of incoming goods. This system is built on standardized device data and cybersecurity.
Rainer Brehm, CEO of Siemens Automation, stated, "The next productivity leap will come from automating tasks that were previously impossible to automate." Brehm noted that the company is taking decisive steps towards AI-powered, autonomous production and strengthening its leading automation portfolio with agent-based and physical AI. Emphasizing the increasing importance of cybersecurity as industrial AI becomes more prevalent in production, Brehm highlighted Siemens' nearly 40 years of experience in cybersecurity and regulatory compliance.
👁️🗨️ Robots with Real-Time Environment Perception
Siemens is also developing an AI solution where cameras capture the environment in real time, and AI-based robot foundation models interpret the situation to autonomously determine the necessary steps. This robot can open cardboard boxes and remove component reels for further processing. The company provides automation, control systems, industrial PCs, software orchestration, and domain expertise gained from its own production facilities.
💻 Innovations in Engineering with TIA Portal V21.1
For automation engineering, Siemens has expanded its existing automation software. With the new TIA Portal V21.1, customers can purchase features instead of versions, meaning project updates are no longer required within the V21 version line. Functional enhancements include multi-core support in the PLC program for SIMATIC S7-1500 and extended SIMATIC Resource Documents, which now also cover hardware configuration and can be processed by AI systems.
🧠 AI Cycle in Production: Industrial AI Suite
During production, Siemens' Industrial AI Suite brings AI directly into automation. AI models running on Industrial Edge can connect to SIMATIC S7 controllers via PROFINET, providing real-time AI inference as part of machine automation. This paves the way for use cases such as AI-based motion control. Production data can also be used to retrain, validate, and redeploy AI models in-house, creating a closed AI loop from deployment to operation and continuous improvement.
🔒 Cybersecurity and AI
The company stated that cybersecurity is integrated into these tools, and AI is used to enhance cybersecurity. Siemens is preparing relevant products in its industrial portfolio for the applicable requirements of the EU Cyber Resilience Act and supports machine manufacturers in preparing their machines for the CRA requirements, which will be effective from December 11, 2027.
