Siemens has introduced LOGO! 9, the latest version of its compact logic controller series LOGO!, designed for small-scale automation tasks. This innovation marks the first major update to the LOGO! platform in 11 years. LOGO! 9 offers significant improvements over previous models with its user-friendly interface, high processing capacity, and enhanced security measures.
### LOGO! 9 Features
- Double the logic processing capacity of previous models with 800 function blocks
- Maximum 64 digital inputs and 60 digital outputs
- Support for 16 analog inputs and 16 analog outputs
- Increased precision with the new analog expansion module (AM4)
- Base unit with integrated 320 x 240 pixel color touchscreen
- Option for a 4.3-inch, 480 x 272 pixel resolution text display and dual Ethernet ports
- Advanced calculation capabilities with floating-point mathematics
- Easy setup and programming via USB
- Multi-platform support (Windows, macOS, Linux)
- Role-based user management (UMAC) system
- Secure boot and communication protocols
- Firmware update and factory reset option for easy maintenance
### Advanced Hardware and Software
Thanks to its expanded I/O capacity, LOGO! 9 can perform complex automation tasks that previously required multiple devices, all within a single system. The new analog module enhances the accuracy of sensor data in areas such as environmental monitoring, process control, and building management. The integrated color touchscreen allows users to easily view system status and diagnostic information, while models with larger displays provide real-time and secure machine monitoring.
The new controller is programmed with LOGO! Soft Comfort V9 software. The software offers easy installation via USB and remains compatible with projects from previous LOGO! versions. It can also be used on Windows, macOS, and Linux operating systems. The new user management system simplifies the management of access rights for different user roles.
### Security and Environmental Approach
LOGO! 9 is protected against unauthorized access and tampering through secure boot and secure communication protocols. Furthermore, firmware updates for easy maintenance and lifecycle management can be performed via LOGO! Soft Comfort. The device's IP address is preserved even when factory reset, reducing configuration time.
Siemens also supports environmental and efficiency goals with LOGO! 9, and the device carries the EcoTech label. The LOGO! family combines advanced features such as user interaction, data processing, and cybersecurity with its compact design, offering a powerful solution for small automation applications.
The new LOGO! 9 controllers will be available on the market starting April 1, 2026.
