🚀 Siemens Brings AI Touch to Process Engineering: Agent-Based AI Coming for SIMATIC PCS 7!
💡 The Future of Automation in Process Industries​
Continuous process industries such as chemical, pharmaceutical, and oil and gas rely on Distributed Control Systems (DCS) to manage complex production assets. The engineering and modification of these facilities require transforming massive instrument and equipment tables, detailing thousands of sensors, valves, and pumps, into structured control logic. Traditionally, automation engineers manually transfer these lists into the control environment and verify each signal routing according to plant specifications. This process can take weeks or months.
🤖 A Revolutionary Solution from Siemens: The Eigen Engineering Agent​
To overcome these engineering bottlenecks, Siemens is expanding its Eigen Engineering Agent portfolio for process industries. First launched in April 2026 for discrete factory automation within the TIA Portal software environment, this agent is now specifically designed for facilities using SIMATIC PCS 7 version 10 and above.
✨ Agent-Based Control Logic Analysis and Automated Module Generation​
The software targets two key engineering workflows:
  • Analysis of Existing Control Logic: Engineers can query existing projects using natural language, trace signal connections, and detect configuration errors.
  • Generating Standardized Control Modules from Raw Engineering Lists: Eigen processes engineering lists, matching sensors, valves, and pumps with standardized project library templates known as Control Module Types (CMTs). It selects the appropriate CMT for each device, generates a corresponding Continuous Function Chart (CFC), and populates parameters such as alarm limits.
📈 Operational Management and Efficiency Potential​
Siemens anticipates potential time savings of 20% to 60% for specific tasks. Eigen operates within the PCS 7 engineering environment, and all AI-generated suggestions are reviewed by engineers and undergo approval processes before going into production. Customers retain ownership of their data.
Rebecca Vangenechten from Siemens states that process plants operate for decades, and critical engineering knowledge is embedded within the projects. She emphasizes that making this knowledge accessible helps PCS 7 users expand and adapt their plants more quickly. Pioneering companies like BASF are among the first to test this agent.
⚙️ Technical Details and Industry Comparison​
SIMATIC PCS 7 graphically interconnects standardized function blocks using Continuous Function Charts, in accordance with standards like IEC 61131-3. Traditionally, transferring instrument lists derived from P&IDs into PCS 7 relied on spreadsheet-based bulk engineering or manual configuration. This often led to errors, such as incorrect alarm limits or signal scaling, only being discovered during Factory Acceptance Testing (FAT).
Siemens' Eigen Engineering Agent positions itself against competitors like Emerson (DeltaV), ABB (System 800xA), Honeywell (Experion PKS), and Yokogawa (CENTUM VP) in their efforts towards engineering efficiency and AI-assisted configuration. By integrating agent-based reasoning directly into the SIMATIC PCS 7 engineering environment, Siemens offers a verifiable and human-centric engineering workflow.
