✨ Revolutionary Solution from Lenze: Motor Drive System IE5/IE6
Lenze is breaking new ground in the intralogistics sector with its Motor Drive System IE5/IE6, introduced at the SPS 2026 fair. This system offers significant advantages in conveyor systems by providing positioning, synchronization, and torque control without an external encoder.
⚙️ Core Technology and Architecture
Many conveyor tasks are positioned somewhere between simple speed control and a full servo axis: loads need to stop precisely, belts need to start under load, and modules need to accelerate and decelerate repeatedly. Traditional servo axes with encoders require additional components, cabling, and engineering effort that are not always necessary for these tasks.
In Lenze's new system, the m550 permanent magnet synchronous motor works with Lenze inverters that determine the rotor position without an encoder. This allows positioning, synchronization, torque control, and dynamic start-stop movements to be achieved with fewer components and interfaces. According to Lenze, up to 30% of existing servo applications can now be implemented without an encoder.
The m550 motor and g500 gearbox form a compatible unit. The motor achieves IE5 and IE6 efficiency classes without needing a larger frame size and reduces motor losses by up to 60% compared to an IE3 motor, including at partial load. Overload torque of up to 300% provides short-term reserves, allowing drives to be sized for continuous operation rather than peak loads.
🛠️ Application and Integration
The i650 motec decentralized frequency inverter moves control to the axis. Its integrated Logic PLC handles control and positioning independently, reducing reliance on the central controller and the need for control panel space. Four IO-Link ports provide field data for IIoT and predictive maintenance. Braking energy is fed back into the grid instead of being dissipated in a braking resistor. The i650 motec covers a range of 0.37 to 45 kW and connects via common Industrial Ethernet and safety protocols.
Sensorless control is also available in the i510, i550, i650, i750, and i950 inverter series. This allows machine builders to scale from frequency inverters to high-performance servo inverters with the same control principle.
🏭 Industrial Applications
At the SPS fair, the i650 motec was featured in various exhibits, including Dynamic Performance, an electric monorail system, a belt conveyor, and drive packages for horizontal transport with a turntable. Typical applications include conveyors in warehouses and production logistics, sorters, packaging machine modules, and monorail systems.
📈 Operational Impact and Performance Metrics
Removing the encoder eliminates a sensor, its cable, and its connector, which are common points of failure in conveyor installations, and reduces commissioning effort. The up to 60% reduction in motor losses compared to IE3 and the feedback of braking energy into the grid lower energy consumption over the machine's lifespan.
