Elif Ă–zaksu
Modern manufacturing facilities continuously generate large amounts of operational data. However, this data often remains trapped in isolated factory systems. Traditionally, connecting these operational technologies (OT) with high-level enterprise IT and cloud platforms requires complex and difficult-to-maintain IoT middleware.
These additional software layers create data processing bottlenecks, increase infrastructure costs, and necessitate extensive data preparation. For industrial companies, this makes it challenging to transfer contextualized production data in real-time. This, in turn, hinders the efficient development, training, and global scaling of machine learning models across multiple production sites.
đź’ˇ End-to-End IT/OT Integration: Is This the Solution?
To overcome these structural barriers, a direct system architecture has been implemented that connects edge devices on the factory floor to a central cloud data and AI platform without using complex middleware. This technical solution relies on the interaction of an industrial edge platform with a cloud-agnostic analytics environment.
Data transfer is managed via a dedicated, industrial-grade data pipeline. This application directly receives, contextualizes, and continuously routes data from production equipment. This creates a closed-loop workflow: Cleaned factory data forms the basis for training advanced algorithms in the cloud. The completed models are then redeployed to local edge devices and operate directly within the production process, close to the physical machines.
⚙️ Technical Specifications and Automated Data Pipelines
The edge layer uses a central integration hub for industrial data to securely expose isolated information from controllers and machines. The local application ecosystem ensures low-latency data processing and high system availability, which are necessary for executing safety-critical processes.
The FFT DataBridge application acts as the connection bridge. This software functions as a ready-to-use gateway that eliminates manual and costly data preparation. It transforms raw production data into AI-ready datasets and securely transfers them in encrypted form to the Databricks platform. In the cloud environment, information is centrally managed to support applications such as predictive maintenance, quality optimization, energy management, and the control of autonomous processes.
Volker Stark, COO of FFT Produktionssysteme, explains, "The solution is ready-to-use and does not require complex, costly data preparation. By locally connecting IT and OT, we eliminate complex IoT layers and significantly simplify industrial connectivity."
📊 Operational Benefits and Global Scalability
The combination of central data analysis and decentralized execution enables data-driven decisions to be made in real-time. Since the system architecture is cloud-agnostic and standards-based, fully trained AI models can be deployed across global production networks with minimal customization, rather than being tied to a single facility.
Bypassing complex middleware layers reduces the administrative burden and maintenance costs of the IT infrastructure. By deploying optimized algorithms directly to machines, users benefit from more stable processes, reduced downtime thanks to predictive analytics, and increased overall productivity. This end-to-end connectivity forms the technical foundation for future autonomous production workflows.
Rainer Brehm, COO and CTO of Automation at Siemens Digital Industries, states, "Industrial AI only unlocks its value when data, context, and execution come together. Together, we enable our customers to scale industrial AI across equipment and factories and realize AI-powered manufacturing."
This integrated approach represents a significant step towards revolutionizing production processes by fully unleashing the potential of industrial AI.
