🖥️ SCADA Software Comparison: WinCC, Wonderware, Ignition, Citect & Others
  • SCADA software, the visual brain of industrial automation projects, plays a critical role not only in data monitoring but also in operational efficiency, alarm management, reporting, and decision support systems.
    So, which SCADA software stands out in the industry? Which system is more suitable for which project?
    Here's a comparison of the most preferred SCADA solutions 👇
    🔷 1. Siemens WinCC (TIA Portal / WinCC Professional)​
    🔹 Origin: Germany
    🔹 Integration: Siemens PLCs (S7-1200 / 1500), Profinet, OPC UA
    🔹 Advantages:
    • Integrated structure with TIA Portal
    • Robust tag management, web-based access options
    • Comprehensive archiving, data analysis, and reporting
      🔸 Disadvantages:
    • Licensing is complex and costly
    • Limited integration with non-Siemens devices
    🔷 2. AVEVA (Formerly Wonderware InTouch)​
    🔹 Origin: UK / France
    🔹 Integration: Compatible with all PLC brands via OPC
    🔹 Advantages:
    • Highly advanced graphics library
    • Integrated with Historian, MES, and Edge solutions
    • Cloud-based system support
      🔸 Disadvantages:
    • High system requirements
    • Price/performance balance may be perceived as unfavorable in Turkey
    🔷 3. Ignition by Inductive Automation​
    🔹 Origin: USA
    🔹 Integration: OPC UA, MQTT, REST API with all systems
    🔹 Advantages:
    • Browser-based SCADA (Web SCADA)
    • Unlimited tag licensing model
    • Very strong MQTT & IIoT integration
      🔸 Disadvantages:
    • May be challenging for those unfamiliar with Linux and web infrastructure
    • Limited number of engineers in Turkey
    🔷 4. Schneider Citect SCADA​
    🔹 Origin: Australia / France
    🔹 Integration: Directly compatible with Schneider systems
    🔹 Advantages:
    • Advanced security system
    • Preferred in large energy projects
    • Strong alarm & event management
      🔸 Disadvantages:
    • Interface can feel outdated
    • Installation and configuration are complex
    🔷 5. Others​
    • FactoryTalk View (Rockwell) → Compatible with Rockwell systems, integrated HMI + SCADA
    • Movicon (Progea) → Ideal for light projects, has open-source support
    • Zenon (Copa-Data) → Strong in the energy sector, supports IEC 61850
    📊 Summary Table: SCADA Software Comparison​
    SoftwareWeb-BasedOPC UAMQTTLicense TypeMost Compatible PLC
    WinCC✅✅⚠️ModularSiemens
    AVEVA Wonderware⚠️✅⚠️Tag-basedAll
    Ignition✅✅✅Unlimited TagAll
    Citect SCADA⚠️✅⚠️User-basedSchneider
    FactoryTalk View⚠️⚠️⚠️Tag-basedRockwell
    📣 Which SCADA Do You Think Is More Effective?​
    Which SCADA software do you prefer?
    What advantages or disadvantages have you encountered in your projects?
