Ahmet Ă–.
đź’ˇ Complete Solution from a Single Source: End to Integration Problems!
When setting up machine vision systems in industrial automation, hardware, optical, and software components from different suppliers often lead to incompatibilities. Basler offers an innovative solution to eliminate this complexity by combining optical sensors, lighting control, and software development environments into a single ecosystem.
⚙️ Hardware Integration and Synchronization: Speed and Efficiency Combined
- Centralized Synchronization: With a single camera input/output (I/O) interface and an integrated software development kit (SDK), lens settings and lighting triggers are coordinated without the need for external control boards.
- High Bandwidth: Thanks to 10 Gigabit Ethernet (10GigE) interfaces, Remote Direct Memory Access (RDMA), and Power over Ethernet (PoE), high-speed image transfer is achieved even in compact sizes like 29 mm x 29 mm.
- Continuous Surface Inspection: Trilinear color line scan cameras offer seamless surface inspection in continuously fed processing applications.
đź’» Virtual Engineering and Application Workflows: Accelerate Development Processes
Basler shortens development times with virtual simulation and automated engineering tools before physical installation:
- Simulation: Virtual modeling engines generate synthetic training data for AI models and simulate optical geometries (focal lengths, illumination angles, sensor formats) before physical hardware is installed.
- Automated Agents: A vision simulation agent works with a dedicated coding agent to translate optical parameters directly into functional firmware configurations and runtime control scripts.
- Environmental Protection: IP67-rated, ingress-protected hardware can be placed directly on factory floors without the need for additional enclosures.
🎯 Application Scenarios and System Efficiency: A Wide Range of Uses
This integrated system targets areas such as logistics verification, autonomous mobile robots (AMRs), and discrete manufacturing:
- Logistics: In high-speed logistics lines, AI-powered optical character recognition (OCR), barcode reading, and volumetric sizing of moving objects are performed simultaneously.
- AMRs: Compact 2D and 3D spatial vision modules maintain edge processing stability while meeting strict constraints on payload capacity, volume, and power consumption in AMRs.
Basler eliminates the need for peripheral synchronization hardware and stabilizes integration latency in high-throughput production lines by combining lighting timing, optical focus, and data transmission in unified SDK pipelines. These systems will be showcased at the VISION 2026 exhibition in Stuttgart, Germany, from October 6-8, 2026.
