✨ Efficiency in Production with Smart Vision
In automated packaging, food processing, and intralogistics lines, verifying container fill levels is critical to comply with net content regulations, prevent spillage, and minimize material waste. Traditional single-point sensors fall short in capturing true volume or surface peaks in containers with irregular solids, viscous liquids, or unevenly distributed bulk materials. Contrinex solves this problem with its 3D smart camera and the new "Fill Level Measurement" feature.
💡 The Power of 3D Vision: Beyond Single-Point Sensors
Instead of relying on a single depth reading, Contrinex's 3D smart camera captures spatial height data across the entire opening of a container. The Fill Level Measurement use case within the Smart Vision App processes this spatial data to derive five distinct metrics from a single image:
- Fill Ratio: Determines container capacity utilization as a percentage.
- Total Volume: The total volume of material within the container.
- Maximum Height: Detects the highest point of the contents and potential overfill conditions.
- Minimum Height: Detects the lowest point or voids in the fill profile.
- Differential Height: Assesses surface flatness and height variations in the measured material distribution.
This multi-parameter approach enables quality control systems to detect irregular placements, mounds, or sloped fill surfaces that standard level sensors would miss. For automated line integration, operators can assign upper and lower tolerance thresholds to each parameter, and the camera evaluates live measurements against these rules, providing a binary PASS/FAIL signal to the PLC or rejection mechanism.
⚙️ Codeless Configuration and Easy Integration
One of the primary barriers to the adoption of 3D machine vision on the factory floor is the engineering overhead required for calibration, region-of-interest definition, and algorithm tuning. Contrinex addresses this with an embedded, browser-based workflow within the Smart Vision App.
Instead of coding point cloud filters, technicians use a step-by-step configuration wizard. The workflow guides the user through defining the container's virtual geometry, teaching the target object reference, and setting numerical pass/fail thresholds for volume, fill percentage, and height limits. Since image processing algorithms run directly on the smart camera, the system eliminates the need for external processing units and reduces integration complexity on existing conveyor lines.
🏭 Industrial Applications: Food, Beverage, and Logistics
In the food and beverage industry, contactless 3D fill inspection prevents underfilled packages from reaching consumers while catching overfilled containers before they contaminate heat-seal jaws or capping heads. For dry goods, baked products, or granular contents where material heaping occurs, differential height measurement ensures consistent portioning and package integrity.
In automated logistics and order fulfillment processes, the same inspection capabilities verify the fill ratios of totes and cartons before automated storage, capping, or shipment. Measuring maximum height ensures that protruding items do not jam downstream conveyors or automated guided vehicles, while fill percentage tracking optimizes container volume utilization.
🚀 The Future of Automation: Edge-Based Vision Processing
In the broader industrial automation landscape, embedded 3D smart cameras represent a shift towards edge-based vision processing. Competing industrial vision manufacturers such as SICK, IFM Electronic, and Keyence offer comparable standalone 3D time-of-flight and triangulation sensors equipped with built-in application wizards for volume and level monitoring. In this product category, standardization in codeless graphical setup tools allows plant maintenance teams to deploy and recalibrate optical inspection stations during product changeovers without external system integrators, aligning with broader industry trends towards flexible, modular production lines.
