🚀 Revolutionary Robot from Siemens: SINUMERIK MTR in North America! 🚀
    Siemens is revolutionizing industrial automation with its new SINUMERIK Machine Tool Robot (MTR) introduced to the North American market! These 6-axis robots are now taking on the tasks of traditional machining centers, combining precision and flexibility.
    🤖 Breaking Down Barriers Between Robots and Machine Tools 🤖​
    Traditionally, machine tools were used for high-precision cutting operations, while industrial robots were preferred for lower-precision tasks such as loading, welding, and deburring. The main reason for this was the occurrence of path deviations as cutting forces increased due to the flexibility of the robot's arm structure. Especially hard materials like steel exacerbated this problem as they required higher cutting forces.
    ✨ A New Era with SINUMERIK MTR ✨​
    Siemens' SINUMERIK MTR offers a solution to these problems with an innovative control concept. Providing 200% to 300% better path accuracy and significantly higher dynamic rigidity compared to traditional industrial robots, the MTR enables high-precision applications even with hard materials like steel. Furthermore, it offers an ideal solution for applications that do not require process forces, such as waterjet and laser cutting, by increasing production efficiency by 20% to 40%.
    🧠 Ease of Programming in a Single Environment 🧠​
    The MTR is controlled by SINUMERIK ONE, Siemens' native digital CNC platform. This allows manufacturers to program robots and machine tools in the same familiar CNC environment, eliminating the need to learn separate robot programming languages. Additionally, thanks to digital twin technology, simulations and tests can be performed in virtual environments before the robot makes any physical movement.
    🚀 Broad Application Areas and Future Manufacturing 🚀​
    SINUMERIK ONE is part of Siemens' Xcelerator portfolio, an open digital business platform for specialized industries such as aerospace, defense, automotive, e-mobility, and energy. The MTR also offers significant advantages in areas such as high-precision post-processing of 3D-printed metal parts.
    Zachary Gray, President of Siemens Machine Tool Systems America, stated, "Manufacturers have always had to choose between the reach of a robot and the precision of a machine tool. For the U.S. market, the Machine Tool Robot eliminates that choice for a large class of parts. This helps our customers address their precision concerns so they can embark on larger endeavors, such as machining large aerospace structures and additive parts that don't fit into traditional machining envelopes.
    Siemens SINUMERIK Machine Tool Robot
    Siemens’ SINUMERIK MTR combines the flexibility of a 6-axis robot with CNC-level machining control. Powered by SINUMERIK ONE, it delivers improved path accuracy, digital-twin simulation and unified CNC programming for applications including high-precision machining, laser and waterjet cutting.
    Spad Electronic — supporting CNC automation, robotics, motion control and advanced manufacturing systems.
    www.spad1.ir |
