SĂĽeda Asil
A New Era in Industrial Automation: LogixEdge Controllers
As industrial enterprises modernize their legacy production lines, they face the challenge of bridging the traditional divide between operational technology (OT) and information technology (IT). Traditionally, machine builders and plant engineers used specialized programmable logic controllers (PLCs) for sub-millisecond I/O scanning and motion control, while deploying separate industrial PCs and gateways for HMIs, local data historians, machine vision models, and cloud connectivity. These fragmented architectures increased control panel space, complicated inter-device network communication, and led to issues with software updates.
Power United on a Single Platform: LogixEdge
To overcome these integration challenges, Rockwell Automation has launched the LogixEdge controller. Featuring a compact industrial PC-based architecture, this platform combines Rockwell's well-established Logix control engine with open-edge computing capabilities in a single device. This allows manufacturers to deploy visualization, analytics, and digital services directly alongside machine operations without the need for additional gateways.
Containerized Workloads and Software-Defined Automation
LogixEdge natively supports containerized workload execution, enabling engineering teams to consistently deploy, patch, and manage software using modern container orchestration and lifecycle management practices. The platform supports FactoryTalk Optix, Module Type Package (MTP) orchestration, FactoryTalk Remote Access, and custom third-party Docker containers.
Stefano Schiavella, Product Manager at Rockwell Automation, states that industrial automation is transitioning from hardware-centric structures to software-defined systems that simplify scaling and lifecycle management. On the LogixEdge platform, the deterministic control partition executes standard discrete, process, batch, and sequencing routines without being affected by user-selectable edge computing containers.
Advanced Networking and Security
The hardware features a dual gigabit front Ethernet port to maintain deterministic network separation. One interface is dedicated to real-time EtherNet/IP communication for the Logix control engine, while the second port manages open-edge workloads, third-party protocols such as OPC UA, MQTT, and Modbus TCP, and enterprise connectivity.
On the security front, LogixEdge ensures cryptographic device authentication and role-based access enforcement in both the OT control plane and the IT container environment, complying with ODVA CIP Security standards, syslog event forwarding, and the European Union Cyber Resilience Act via FactoryTalk PolicyManager.
Competition and Future
LogixEdge directly competes with rivals such as Siemens (SIMATIC S7-1500V), Beckhoff Automation (TwinCAT 3), Bosch Rexroth (ctrlX CORE), and Schneider Electric (EcoStruxure Automation Expert). By integrating the Logix engine into an Atom-class IPC with FactoryTalk Optix and open Docker containers, Rockwell offers a unified path to software-defined control without forcing users to abandon existing Studio 5000 code bases or PlantPAx process libraries.
