## Cable Connectors Renewed with Optimized Strain Distribution and Ergonomic Design
Binder has introduced a new triangular molding concept for its M12 and M16 connectors to enhance durability, ease of use, and performance in dynamic industrial environments.
In modern machinery, connectors are subjected to mechanical stresses due to movement, vibration, and continuous cable bending. This can lead to material fatigue and reduced reliability. Binder's triangular molding design addresses these issues by increasing mechanical durability and extending the connector's lifespan.
### Optimal Force Distribution
- The triangular molding distributes bending and tensile forces more evenly in the transition area between the cable and the connector, reducing localized stress points.
- Its integrated anti-torsion structure enhances stability, especially with continuous movement in drag chains and robotic systems.
- This design increases durability in harsh operating conditions and reduces the risk of failure.
### Ease of Use and Maintenance
- The structured surface provides a firm grip, facilitating assembly and disassembly.
- The design, which reduces dirt accumulation, simplifies cleaning and maintenance processes for industrial environments exposed to dust, oil, and other contaminants.
### M16 Series Connector Features
- Series 425 is designed for robust signal transmission in machine and plant engineering applications.
- Available with 3 to 12 contact options.
- Capable of carrying voltages up to 150 V and currents up to 3 A.
- Resistant to dust, moisture, and splashing water with IP67 and IP68 protection ratings.
- Gold-plated contacts provide reliable electrical performance.
- Available in both shielded and unshielded versions.
- Directly molded onto PUR cables, with standard lengths of 2 m and 5 m; custom lengths are available upon request.
### Industrial Design and Differentiation
- The triangular molding combines the product's functionality with an aesthetic touch, strengthening brand recognition.
- Requires high precision in injection molding processes for material flow control and prevention of air bubbles.
### Application Areas
- Automation technology
- Machine and plant engineering
- Robotics
- Conveyor systems
- Packaging machines
- Measurement and sensor technology
These connectors are particularly ideal for dynamic industrial environments subject to continuous movement and mechanical stress.
Binder's new connectors, developed with triangular molding, respond to the increasing demands of industrial automation by offering reliable solutions for high-performance applications.
