## Ultra-Compact Industrial PC for Edge Computing from OnLogic: CL260
OnLogic has introduced its new ultra-compact, fanless IPC model, the CL260, specifically designed for demanding industrial environments. This small and cost-effective device is ideal for industrial IoT and automation applications where space is limited.
The CL260 was developed with industrial IoT and edge device needs in mind. Available with Intel N150 or N250 processor options, this fanless computer measures 115 mm x 30 mm x 82 mm and provides easy installation with DIN rail mounting.
### CL260 Technical Specifications
- Processor: Intel N150 or N250
- Dimensions: 115 mm x 30 mm x 82 mm
- Mounting: DIN rail mounting capability
- USB Connections: 4 USB ports, 2 USB-C ports
- Ethernet: 2 GbE Ethernet ports
- Storage: 128 GB M.2 SSD (upgradable to 2 TB)
- Power Input: 12-24 VDC three-pin terminal block
- Operating System and Wireless Connectivity: Not included in the base model, can be added optionally
Although the CL260 is not designed to run advanced artificial intelligence algorithms, it offers sufficient performance for data acquisition and HMI applications. It stands out due to its small footprint in electrical panels, low heat generation, and appropriate power consumption.
In edge computing and industrial IoT solutions, small and cost-effective IPCs are increasingly preferred. The OnLogic CL260 offers an ideal solution for IoT gateways, small HMI applications, and web-based applications. It facilitates integration with tools like the Node-RED programming interface and enables data redirection to cloud services.
The CL260 can seamlessly run most HMI applications operating on Windows or Linux operating systems, thus providing flexible use in industrial data acquisition and control processes.
