Elif Özaksu
💡 Powerful Solutions for Industrial Environments
Modern production lines, hygienic facilities, and outdoor logistics centers require durable computer hardware capable of uninterrupted operation under harsh environmental conditions. Standard hardware frequently fails when exposed to factors such as dust, moisture, corrosive chemicals, and wide temperature variations. Vecow offers embedded computer hardware that integrates high ingress protection, fanless thermal regulation, and vibration-resistant chassis design directly into the visual interface to address these operational constraints.
🧼 Edge Computing for Hygienic Facilities
Facilities in the food, beverage, and pharmaceutical sectors operate under strict sanitation regimes involving pressurized steam, hot water, and corrosive chemical agents. The Vecow STC-7000 Series meets these hygienic requirements with an IP69K and IP68 sealed stainless steel enclosure and industrial M12 waterproof connectors. Thanks to its true flat multi-touch screen, it eliminates recessed edges that could accumulate organic matter or bacteria. Powered by 12th Gen Intel Core processors, these units are available in sizes from 10 inches to 21.5 inches. Its fanless architecture boasts an operating temperature range of -20°C to 60°C, making it ideal for cleanroom, processing area, and automated packaging applications.
⚡ Energy-Efficient Control Architectures for Smart Automation
Decentralized control points on automated assembly lines, automated guided vehicles (AGVs), and smart kiosks require low thermal dissipation and fast processing power for human-machine interaction. The MTA-1000W Series offers energy-efficient computing built on an ARM-based architecture. It is available in 10.1-inch (MTA-1010W) and 21.5-inch (MTA-1021W) sizes. Its fanless design reduces mechanical wear points and power consumption while providing the essential processing power needed for localized edge computing and machine status visualization.
rugged High Computing Power and Mobility for Demanding Field Operations
Field operations in mining, modern agriculture, and emergency services face challenges such as continuous mechanical shock, particulate exposure, and direct sunlight. The Vecow RTP-1000 is a 10.1-inch industrial tablet utilizing 13th Gen Intel Core i7 processor architectures. The device is IP67 rated against dust and water and complies with MIL-STD-810H standards for shock, drops, and continuous mechanical vibration. It features an 800-nit sunlight-readable display for field visibility. Its 10,000 mAh battery offers up to 10 hours of continuous operation within a -20°C to 60°C operating temperature profile.
☀️ Sunlight-Readable Information Systems for Outdoor Infrastructure
Digital signage, outdoor kiosk terminals, and public transport passenger information systems contend with direct sun glare, wide ambient temperature fluctuations, and continuous duty cycles. The UWD-1000 Series delivers high-brightness visual output via a 1,000-nit backlight on 37-inch, 43-inch, and 48.5-inch displays. Configured with an ultra-wide 16:3 aspect ratio, these panels display structured data streams in horizontal transit and infrastructure layouts. The series operates from an industrial 24V DC power source, maintains standard operational integrity between -20°C and 60°C, and integrates into outdoor smart kiosks and edge AIoT environments.
⚙️ Technical Details and Standards
Industrial panel PCs and displays are subject to increasingly stringent international engineering and hygiene standards. In hygienic environments, an IP69K rating (defined under ISO 20653 and DIN 40050-9) tests enclosure resistance against close-range water jets at pressures up to 100 bar (1,450 psi) with flow rates of 14 to 16 liters/minute and temperatures up to 80°C. Stainless steel applications in this class typically use AISI 304 or AISI 316L grades to prevent surface pitting from acid and alkali-based CIP (clean-in-place) agents.
In the rugged industrial PC market, competitors such as Advantech, Siemens, and Axiomtek offer comparable washable terminals and modular HMI platforms. Embedded market benchmarks typically use 11th to 13th Gen Intel Core or low-power Celeron/Elkhart Lake architectures for standard HMIs, while ARM Cortex-A processors (such as the NXP i.MX8 family) serve as the standard low-power baseline. In outdoor display applications, the industry standard for full sunlight readability requires a minimum of 800 to 1,000 nits combined with optical bonding to reduce internal reflection; this aligns with the brightness values offered in both the RTP-1000 tablet and UWD-1000 display series.
