🚀 New Generation N-Tron® Industrial Ethernet Switch Platform from HMS Networks: Uninterrupted Power in Mission-Critical Operations!
Industrial networks are rapidly evolving, becoming more complex, and increasingly dependent on continuous operation. To meet these demands, HMS Networks, a manufacturer of innovative technologies that enable industrial organizations to control, connect, and visualize their data, has announced the new N-Tron® NT7000 Series. This advanced managed industrial Ethernet switch platform is specifically designed for real-world industrial environments where failure is not an option.
⚡ Fast Startup and Rapid Recovery​
When a production line comes back online, time is critical, and even seconds make a difference. The N-Tron NT7000 is designed to minimize downtime. With fast boot-up passing traffic in less than 7 seconds and N-Ring redundancy with a recovery time of approximately 20 ms, it helps operations quickly return to normal after network failures.
⏰ Hardware-Based Precision Timing​
As motion, robotics, and other time-sensitive industrial applications become more prevalent, deterministic timing is no longer a luxury but a necessity. The N-Tron NT7000 supports hardware-based IEEE 1588 PTP for sub-microsecond time synchronization. By moving the timestamping process to hardware, it reduces variation compared to software-based implementations and provides more consistent timing for demanding applications.
⚙️ Simplicity Throughout the Lifecycle​
Faster deployment, easier replacement, smarter support. The N-Tron NT7000 not only performs but is also designed to simplify the daily reality of industrial networks. N-View 3 provides switch and topology discovery, network health monitoring, firmware management, and centralized IP addressing. A micro SD card in the switch supports configuration backup and restore, allowing for faster replacement and recovery. For EtherNet/IP environments, CIP messaging AOI and Faceplate help simplify control integration.
🌐 A Scalable Platform for Modern Industrial Networks​
The N-Tron NT7000 is a platform designed to support a wide range of industrial architecture and installation needs. Multiple configurations and connectivity options are offered, including copper and fixed fiber variants, to fit common compact and complex industrial designs.
🛡️ Certified for Industrial Applications​
The NT7000 is certified for demanding industrial applications that customers actually use. This includes UL Ordinary and Hazardous locations, ATEX and IECEx certifications, as well as IEEE 802.3 compliance and ODVA, marine, rail, and railway rolling stock certifications. The switches are housed in rugged, DIN-mount all-metal enclosures and offer high shock and vibration tolerance, surge protection, redundant power inputs, and extreme operating temperatures.
Barry Turner, N-Tron Product Manager, stated, "Industrial teams consistently tell us they want performance they can rely on without added complexity. The N-Tron NT7000 is designed with that reality in mind: fast startup, rapid recovery, hardware-based precision timing, and tools that make it easy to deploy, maintain, and restore. It's designed to sustain critical operations in environments where continuous operation is paramount."
This new generation switch platform will help businesses achieve their efficiency and reliability goals while shaping the future of industrial automation.
