✨ New Generation I/O Solution for Hygienic Environments from TURCK: TB Clean Series ✨
🏭 Designed for the Food, Beverage, and Pharmaceutical Industries​
TURCK has expanded its block I/O portfolio with the TB Clean Series, developed for demanding washdown environments. These new modules, featuring an IP69K protection rating, stand out with their stainless steel connectors, FDA-compliant housing, and cloud data integration capabilities. For machine builders and plant operators, maintaining signal integrity and equipment hygiene is a significant engineering challenge, especially in environments requiring frequent washing. Standard industrial fieldbus modules can encounter issues such as moisture ingress, chemical corrosion from aggressive cleaning agents, and microbial accumulation in housing crevices. To address these operational weaknesses, TURCK has launched the TB Clean Series, which can be mounted directly on the machine without the need for expensive stainless steel control cabinets.
🚿 Engineering Requirements in Washdown Environments​
Hygiene-critical production facilities regularly use high-pressure, high-temperature washdowns and caustic/acidic cleaning agents. While standard IP67-rated fieldbus devices are protected against temporary immersion, they often fail when exposed to pressurized steam jets or repeated chemical disinfection. Furthermore, traditional housing designs featuring rotary address switches, clear viewing windows, and adhesive labels create physical indentations where product residues and bacteria can accumulate, complicating validation procedures for original equipment manufacturers (OEMs).
Decentralized block I/O systems rated for washdown duty eliminate the need for sensor-actuator cables to run all the way to central control panels. Engineers can place I/O nodes directly on processing and packaging machinery, reducing wiring complexity and installation time, provided that the field hardware complies with strict regulatory and material standards.
🛡️ Hygienic Housing Architecture and Material Compatibility​
The TB Clean Series ensures washdown durability through its specialized mechanical and material architecture. The internal electronics undergo a two-stage molding process and are fully encapsulated with plastics compliant with U.S. Food and Drug Administration (FDA) regulations. To eliminate dead spaces and facilitate flow during cleaning cycles, the housing features smooth, rounded surfaces and does not include physical rotary switches or viewing windows. Integrated spacers create a defined gap between the connectors and the mounting surface, allowing cleaning fluids to flow underneath the module.
All M12 and power connectors utilize corrosion-resistant stainless steel threads. Unused ports can be sealed with blind plugs made of FDA-compliant plastic or stainless steel. Instead of traditional adhesive labels, which can peel under thermal stress and harbor contaminants, identification data, including product connection and serial number, is permanently laser-etched onto the housing as a QR code.
The modules boast IP67 and IP69K ingress protection ratings and have undergone chemical resistance testing against industrial cleaning agents, supported by Ecolab certification. This "compliance by design" approach allows machine builders to streamline regulatory validation and reduce the engineering burden required for machine-specific hygiene approvals.
☁️ Fieldbus Integration and Cloud Connectivity​
The TB Clean Series portfolio encompasses digital I/O modules, IO-Link masters, IO-Link hubs, and network infrastructure components, complemented by appropriate food and beverage cables rated up to IP69K. Multi-protocol Ethernet modules offer configuration and diagnostic support via an integrated web interface. The mounting footprints of the new modules are compatible with TURCK's existing TBEN-L and TBIL block I/O series, simplifying retrofitting and mechanical standardization.
Beyond real-time operational technology (OT) control, the architecture supports vertical data integration into information technology (IT) and cloud environments. Process values and diagnostic module data can be extracted and transmitted via the Message Queuing Telemetry Transport (MQTT) protocol using TAS Edge, a software module within the TURCK Automation Suite (TAS). This enables condition monitoring and predictive maintenance workflows without conflicting with deterministic fieldbus communication.
