🤖 Motion Sensing and Component Architecture in Humanoid Robots: Innovations from TDK! 🚀
Advanced Solutions for Humanoid Robots from TDK​
TDK has expanded its portfolio of sensors and passive components specifically designed for humanoid robots used in areas such as smart manufacturing, logistics, and healthcare. This hardware package supports safe and continuous human-machine collaboration by offering specialized modules for high-precision motion sensing, environmental perception, and electromechanical drive control.
Dynamic Balance and Precise Positioning​
TDK's hardware portfolio addresses the needs of robots for dynamic balance and precise spatial grasping. This architecture integrates Micro-Electro-Mechanical Systems (MEMS) Inertial Measurement Units (IMUs) equipped with low-noise gyroscopes and accelerometers. Motor noise and structural resonance are reduced thanks to internal vibration suppression algorithms. IMUs measure angular velocities up to 4,000 degrees per second and acceleration ranges up to ±32 g, providing real-time posture, acceleration, and angular velocity data for robot heads, bodies, and joint mechanisms.
Magnetic Angle and Position Sensing​
Robotic modules measure changes in magnetic field direction using tunnel magnetoresistance (TMR) angle sensors. This enables contactless angular position sensing with high precision and low power consumption. The integrated magnetic position sensing infrastructure combines a 6-axis IMU with a 3-axis TMR-based magnetometer. This configuration, processed via on-chip sensor fusion software, calculates rotational, linear, and switch states, allowing robot joints, motor rotors, and precise manipulators to perform complex spatial positioning without direct mechanical friction.
Thermal Regulation and Communication Hardware​
Continuous operation in industrial environments generates significant thermal loads in robotic power modules and battery arrays. To provide system-level overheating protection, the TDK portfolio includes glass-encapsulated Negative Temperature Coefficient (NTC) thermistors, ring terminals, and attachable chips that monitor thermal fluctuations in motor windings and driver boards. For reliable actuator signaling, the architecture uses automotive-grade passive components such as Common Mode Coils (CMCs) and Multilayer Ceramic Capacitors (MLCCs). These components stabilize wired communication networks and provide Electrostatic Discharge (ESD) protection, preventing local signal interference or system failure during physical interactions with human operators.
Additional Information: TDK's Competitive Advantage​
In the robotic sensor components sector, manufacturers such as STMicroelectronics and Bosch Sensortec also develop high-performance IMUs and magnetic sensors for spatial orientation and automated motor control. When evaluating these sensor architectures, primary benchmarking criteria include acceleration measurement range, angular velocity thresholds, and spatial footprint. While competitors often utilize capacitive and Hall effect mechanisms for angular sensing, TDK differentiates its architecture through the direct integration of Tunnel Magnetoresistance (TMR) technology with 6-axis IMUs and dedicated sensor fusion processing. This TMR methodology generally provides higher signal-to-noise ratios and lower operational power consumption compared to traditional Hall effect sensors, offering an optimized architectural approach for battery-powered humanoid platforms requiring long operational cycles and compact joint module designs.
TDK’s expanded humanoid robotics portfolio highlights how precise sensing, motion feedback, thermal monitoring, and reliable communication components work together to enable safer and more responsive robotic systems.
Spad Electronic develops and integrates electronic, embedded, sensing, control, and industrial automation solutions for advanced robotics and intelligent machinery.
🌐 www.spad1.ir | ✉️
