🔋 Maxell's Solid-State Battery Revolutionizes Yokogawa PLCs! 🚀
Maxell Technology in Yokogawa's New PLC​
Maxell has announced that its ceramic-packaged all-solid-state battery "PSB401010H," which is in mass production, is being used in the "OpreX Universal Autonomous Control System" programmable logic controller (PLC) released by Yokogawa Electric Corporation. This marks the first time the PSB401010H has been used in a PLC.
Solution to Battery Issues in PLCs​
PLCs serve as critical industrial control computers in manufacturing plants and infrastructure. They traditionally rely on non-rechargeable primary batteries to maintain internal Real-Time Clock (RTC) data during power outages. This creates ongoing operational burdens such as battery handling, maintenance, and periodic replacement.
Yokogawa's "OpreX Universal Autonomous Control System" supports open industry standards like IEC 61131-3, offering scalability and flexibility to optimize manufacturing processes.
Long Life, Low Total Cost of Ownership, and Wide Operating Temperature Range​
Maxell's PSB401010H battery offers the inherent long life and high reliability of all-solid-state batteries. As a rechargeable battery, it is expected to facilitate continuous system operation. By reducing the frequency of battery replacement, it helps lower the Total Cost of Ownership (TCO) by decreasing shipping costs and replacement labor, while also minimizing environmental impact.
Furthermore, the PSB401010H provides stable performance for the "OpreX Universal Autonomous Control System" across a wide operating temperature range of -20°C to 70°C. This broad thermal envelope supports robust deployment in challenging environments such as cold regions, high-temperature facilities, and marine installations, where traditional PLCs relying on primary batteries encounter operational limitations.
Maxell's Contribution to a Sustainable Future​
In line with its corporate slogan, "Micro batteries. Maximum impact.", Maxell continues to develop compact batteries around four core pillars: long life, high heat resistance, high power output, and wide capacity. The goal is to commercialize batteries for areas where conventional batteries are unsuitable and contribute to a sustainable society.
Additional Information on Solid-State Batteries​
In industrial PLCs, maintaining accurate Real-Time Clock (RTC) timestamps during main power outages is crucial for alarm logging, batch traceability, and compliance in regulated process industries. Traditional primary lithium coin cells can degrade faster at high control panel temperatures, which may necessitate periodic replacement.
All-solid-state batteries in hermetically sealed ceramic packages replace the liquid organic electrolytes of conventional cells with non-flammable solid inorganic electrolytes. Since solid electrolytes are less prone to leakage and thermal degradation, rechargeable all-solid-state cells can be charged from the device's own power source during normal operation and used across a wide temperature range.
