Innovative Drive System for Smart Logistics from FAULHABER
    ## Innovative Drive System for Smart Logistics from FAULHABER
    With its new DualGear drive system, FAULHABER offers high performance, durability, and precision in modern transport and logistics applications. This innovative system combines BX4 motor and GPT gear technologies in a single compact unit, providing an ideal solution for environments with space constraints.
    ### DualGear System Advantages
    • Ability to perform two simultaneous movements with a single drive system
    • Compact and diameter-compatible design
    • High dynamic performance and robustness
    • Easy to integrate, reducing installation and system costs
    ### Technical Specifications
    • Motor: 32 mm diameter brushless BX4 motor (42 mm and 68 mm length options)
    • Gear Unit: GPT series metal planetary gearbox, diameter-compatible mounting on both ends of the motor
    • Precise detection of rotor position with Hall sensors (sine/cosine output signals)
    • Speed and torque adjustment capability with up to three gear stages
    • Durable and reliable structure without the use of adhesives thanks to welded connections
    ### Application Areas
    DualGear is particularly suitable for use in conveyor belts and compact wheel drives of autonomous logistics systems. It offers high-performance and economical solutions in intralogistics environments where space is limited, while providing efficiency in system architecture by allowing a single drive to manage two simultaneous powerful movements.
    This innovative drive system from FAULHABER sets new standards for professionals in the transport and logistics sectors seeking control precision, durability, and ease of integration.
