i.safe MOBILE IS380.1: Bridging Traditional Radio and Mobile Networks
    ## i.safe MOBILE IS380.1: Bridging Traditional Radio with Mobile Networks
    The IS380.1, as a cost-effective 4G radio device, enables digital transformation without compromising user experience.
    ### Introduction
    i.safe MOBILE has announced the IS380.1, a 4G radio device running on the Android™-based IS-OS 16 operating system and certified for Zone 1/21 hazardous areas. This device stands out as an ideal transitional solution, bridging the gap between traditional radio communication and modern mobile networks.
    ### Seamless Transition in Digital Transformation
    Designed for the logistics, railway transportation, port operations, manufacturing, and construction sectors, the IS380.1 maintains the ergonomics users are accustomed to, eliminating the need to switch to new devices or workflows. It supports advanced digital features such as Push-to-talk over Cellular and Mission Critical Push-to-talk.
    ### IS380.1 Features
    • 4G radio communication
    • i.safe MOBILE operating system IS-OS 16 (Android-based)
    • Zone 1/21 hazardous area certification
    • Supports 2G, 3G, and 4G networks
    • Touchscreen and classic two-way radio design
    • Large, tactile Push-to-Talk (PTT) button
    • Programmable rotary switch (channel and volume control)
    • Emergency SOS button
    • IP68 dust and water protection
    • MIL-STD 810H shock, vibration, and extreme temperature resistance
    • 13-pin ISM interface for professional audio accessory compatibility
    • Multi-unit and desktop charging support
    ### Compatibility with Existing Devices
    The IS380.1 is designed to integrate with existing radio equipment. It supports accessories such as the IS-RSMG2.1 remote speaker microphone, IS-HS1.1 headset, and the heavy-duty IS-HDHS1x.1 headset. Users can adapt to the device without a new learning curve.
    ### Unified Communication and Flexibility
    Thanks to RoIP (Radio over IP) gateways, the device combines VHF/UHF radio networks with mobile Push-to-Talk applications. This allows field workers to communicate seamlessly with traditional radio users while also benefiting from the advanced features of mobile networks.
    ### Designed for Professional Environments
    The IS380.1 boasts IP68 and MIL-STD 810H durability standards to meet the demands of harsh industrial environments. Continuous operation is ensured with a replaceable battery. This device can be safely used across a wide range of sectors, from logistics to public safety.
    ### Market Launch
    The IS380.1 will be launched in June 2026 through i.safe MOBILE's global distribution network.
    This device offers significant conveniences and cost advantages to industries as a new step in the digitalization of professional communication.
