How to choose an inverter for solar power systems?
elyesayse
  • Bireysel
  • What is an Inverter? To briefly explain, we can say that it is a device frequently used for solar energy systems.
    It is used to transfer the direct current, or electricity, obtained from solar panels to desired living spaces. Inverters also have the ability to convert alternating current in living spaces into electrical energy.
    These devices perform a special conversion and offer the advantage of use at the desired capacity. It is also possible to analyze the electric current through the inverter. The correct selection of Solar inverter models, which have such important features, requires great care.
    What Factors Should Be Considered When Choosing a Solar Inverter?​
    Inverter Type​
    You should start by choosing the right inverter type that will fully meet your needs for electrical current. Solar inverter models are divided into 3 different types.
    String Inverter Models​
    This is a very popular type. It is also a budget-friendly option in terms of price. Through the inverter, direct current is easily converted into alternating current. String inverter types are especially suitable for small and medium-scale applications.
    Micro Inverter Models​
    As the name easily suggests, these are small devices used in every solar panel. Through these special models, each panel operates independently. This provides much greater efficiency.
    Hybrid Inverter Models​
    Known for their versatility, these are user-friendly products that can connect to solar panels and batteries. They are devices that stand out most for their ease of energy storage.
    Power Capacity​
    An important consideration during inverter selection is its power. It is very important to choose an inverter with a power parallel to the production capacity of the existing solar energy panel.
    Efficient Structure​
    An efficient inverter converts the energy obtained from the panel into AC. Its efficient nature minimizes energy losses during conversion.
    Durable Structure​
    Solar energy panels generally have a lifespan of 25 years. The lifespan of solar inverter types can increase or decrease depending on the characteristics of the point of use. Generally, it is possible to talk about a lifespan ranging from 5 to 10 years.
