Great news for those seeking efficiency and precision in large-scale production! GROB is preparing to showcase its innovative solutions, which will transform production processes from start to finish, at the AMB Fair in Stuttgart in 2026. So, what are these revolutionary technologies, and what contributions will they make to the industry?
βββββββββββββββββββββββββ
π‘ The Heart of Digital Manufacturing: Integrated Robotics and Software π€
GROB, by joining forces with its industrial software partners, has integrated robotic material handling systems with digital production networks. This has led to a groundbreaking level of optimization in high-precision part manufacturing. The system combines gantry milling centers, modular automation cells, and manufacturing execution systems (MES) to stabilize machine utilization and significantly reduce setup times.
π§ Challenges and Solutions in Large Component Manufacturing π οΈ
The production of large and complex industrial components requires extremely robust machining platforms to dampen structural vibrations and maintain mechanical tolerances. However, high-precision machining centers often face low utilization rates due to manual loading processes, complex clamping geometries, and fragmented production data. GROB offers a systematic approach to address these efficiency losses by combining mechanical axis speed with automated material handling and unified data architectures.
βοΈ Automated Material Handling and Mechanical Features π
To automate large part production, GROB-WERKE is introducing the GP1350 5-axis gantry milling machining center in conjunction with the GRC-M60 modular robot cell. The machining center features a robust gantry design to dampen structural vibrations during heavy cutting operations, while the 5-axis configuration allows operators to complete complex geometries in a single clamping cycle.
Material handling is managed by the GRC-M60 robot cell, which acts as a modular automation interface. The robot cell transfers parts directly into the machine's work area, reducing waiting times between production cycles. This modular automation layout allows the cell to be integrated into existing workshop layouts or expanded for scaled serial production.
π Digital Infrastructure and Execution Logic π»
The mechanical system operates under the control of a unified digital infrastructure using the COSERA manufacturing execution system (MES) and a fully integrated tool management system. The architecture relies on standard industrial communication interfaces to connect the physical machine tool, the robotic cell, and the central planning software.
[]Process Transparency: MES monitors and displays real-time production data, mapping machine status, cycle times, and resource utilization.
[]Tool Management: The integrated tool system monitors tool wear and resource availability, planning preventive maintenance and tool changes without stopping the production line.
- Downtime Prevention: By matching planned work orders with real-time tool availability and robotic part loading, the digital system minimizes unplanned machine downtime.
π¬ Production Tests and Application Areas π
The integrated system will be exhibited under operational conditions at the AMB Trade Fair (Hall 10, Stand C12) in Stuttgart, Germany, from September 15-19, 2026. The system targets high-precision, demanding sectors such as industrial automation, aerospace, defense, and semiconductor manufacturing. Thanks to the combination of rigid 5-axis kinematics, automated robotic loading, and MES data routing, the system offers a predictable framework for both small-batch production and high-volume automated serial production.
GROB's innovative solutions aim to set future production standards, raising the bar for efficiency and precision in industrial processes. These systems, which combine the power of digitalization and automation, stand out as a significant step to increase the competitiveness of businesses.
