🚀 Compact AI Systems for Confined Spaces: Revolutionizing Industrial Infrastructure!
💡 The Importance of Local Data Processing in Industrial Infrastructure​
IBASE Technology has launched the ASB110-PI900, an ultra-compact artificial intelligence (AI) inference system designed for smart kiosks, retail terminals, and industrial equipment. This platform addresses the need for local data processing in the digital infrastructure sector, physically positioning computing hardware closer to sensors, cameras, and connected devices to minimize latency.
⚙️ Hardware Architecture and Processing Capabilities​
The system's physical dimensions are 140 x 95 x 60 millimeters, making it ideal for deployment in environments where standard industrial PCs cannot fit. The system architecture is built around the PI900F PICO-ITX motherboard, configured with Intel Core Ultra 7 155U or Ultra 5 125U processors. To support the intensive multitasking and rapid data processing required for edge AI inference, the system accommodates up to 48 gigabytes of DDR5-5600 memory. This combination of processing power and high-bandwidth memory enables the system to manage complex workloads such as real-time retail analytics and automated equipment monitoring without requiring cloud-based processing.
🔗 Connectivity and Digital Infrastructure Integration​
To interface with various peripheral devices and industrial sensors, the system includes comprehensive input and output connectivity. Display capabilities are managed via an HDMI port and a DisplayPort transmitted through USB Type-C, allowing for dual-display configurations. Peripheral and network connections are supported by three USB 3.2 ports and a 2.5 Gigabit Ethernet (2.5GbE) port, ensuring high-speed data transfer between local devices and broader network architectures.
For storage and wireless expansion, the motherboard includes dual M.2 sockets. These interfaces allow system integrators to install NVMe or SATA solid-state drives along with optional WiFi and Bluetooth modules, providing flexibility for diverse deployment requirements.
🔒 System Security and Mounting Configurations​
Deploying computing hardware in accessible or remote edge environments necessitates robust physical and hardware-level security. The ASB110-PI900 utilizes a 12-volt direct current (DC) input and integrates a Trusted Platform Module (TPM 2.0). This cryptographic processor provides hardware-based protection, safeguarding sensitive data and cryptographic keys against unauthorized access. To accommodate different equipment layouts across various industries, the system chassis supports multiple installation methods, including standard desktop placement, VESA mounting, and optional wall or DIN rail configurations.
📈 Competitive Analysis and Technical Specifications​
In the industrial edge computing market, several ultra-compact systems designed for localized AI inference exist. Manufacturers such as Advantech, AAEON, and Axiomtek produce comparable PICO-ITX and nano-ITX form factor computers utilizing low-power x86 architectures. Benchmarking in this hardware category is typically based on physical dimensions (total volume), maximum memory bandwidth, and the neural processing capabilities of the integrated chipset.
While standard compact industrial PCs often employ older-generation processors limited to standard x86 instruction sets, systems integrating current-generation processors like the Intel Core Ultra series leverage integrated Neural Processing Units (NPUs) to accelerate machine learning workloads without the need for a discrete, high-power graphics processing unit. Objective competitive metrics also include high-bandwidth network integration, such as 2.5GbE interfaces, and hardware-level encryption standards like TPM 2.0 to protect localized digital infrastructure against physical and network-based tampering.
IBASE’s ultra-compact ASB110-PI900 highlights the growing role of edge AI in industrial infrastructure, bringing processing closer to sensors and devices for lower latency, greater responsiveness, and secure local computing.
Spad Electronic develops and integrates electronic, embedded, sensing, control, and industrial automation solutions for connected and intelligent industrial systems.
🌐 www.spad1.ir | ✉️
