🏭 Artificial Intelligence and Manufacturing: Field Experiences and Success Strategies 🚀
  • HSCQ
    Challenges and Solutions for AI in Manufacturing​
    To create real value on the manufacturing floor, artificial intelligence (AI) models must not only be technically sound but also overcome operational and commercial challenges. As an account lead, I've observed four key patterns that illustrate why AI projects fail, while bridging the gap between AI teams, factory operations, and senior executives.
    1. Why Pilot Projects Die at System Boundaries 💀​
    A large manufacturer might use dozens of different ERP, MES, and PLM systems. This fragmented structure is where AI pilots often fail. For example, even in an ideal AI problem like "production-ready" visibility, there might be no connection between sales data and production data. In the process from order placement to delivery, the manufacturer might not even see that an order has been canceled.
    Solution: Successful manufacturers overcome this by building a unifying platform instead of individual integrations. This platform consolidates all operations and customer interactions into a single digital environment. Factory and machine data from sensors, combined with cloud-based IoT infrastructure and edge analytics, ensure the seamless flow of AI-powered processes. The key is to fix the system boundaries, not just the algorithm.
    2. Governance Can't Keep Up with Machine Speed 🐢​
    Predictive maintenance programs stall not because of model quality, but because governance processes move slower than the machines. When a model provides a real-time recommendation (e.g., to shut down a line), this decision needs to be made and implemented quickly. Weekly meetings and lengthy approval chains become a bottleneck for real-time recommendations.
    Solution: A structural change is needed. There should be teams that develop capabilities, a separate team that operates the platform, and a distinct governance team that manages the entire process and makes decisions. This separation prevents those who build from making governance decisions under delivery pressure. This way, "go" or "not yet" decisions can be made at the speed required by the field.
    3. The Real Bottleneck Isn't Technology, It's Adoption 🤝​
    Sometimes, even a perfectly designed application isn't adopted by operators. This is because traditional methods are already integrated into shift operations. Operators might prefer older methods they've used for years, trust, and know work even at 2 AM. Multi-million dollar operations can still be run with Excel spreadsheets and macros.
    Solution: Trust isn't earned by offering a better dashboard. Trust is earned through workflow fit and participation. Operators should have a say in how the system works and see how the new system fits into their existing shift schedule. Adoption is won before deployment; successful projects view operators as co-designers, while unsuccessful ones see them merely as an audience.
    4. AI ROI Dies Without Commercial Ownership 💸​
    Underlying the other three patterns is a commercial gap: the lack of real KPIs that measure the return on investment (ROI) of AI initiatives. Projects are treated as pilots, but how value will be realized or who will be responsible is not defined. This situation causes AI to remain merely a cost center.
    Solution: Every AI project must have a clear commercial owner, and this owner should be held accountable for how AI contributes to business outcomes. ROI should be measured not just by technical successes, but by tangible business value. This ensures that AI moves from being an experiment to an integral part of the business.
