Alper AktaΕ
EndΓΌstri Vadisi
As the winds of digital transformation blow through the world of industrial automation, Daudin steps onto the stage with its new generation modular remote I/O platform, iO-GRID X. This platform offers a flexible and scalable way for machine builders, OEMs, and automation integrators to connect field devices to industrial control systems. Complex wiring and large control panels are now a thing of the past!
βββββββββββββββββββββββββ
π‘ The Key to Digitalization: Remote I/O Technology
As manufacturers embrace Industrial Internet of Things (IIoT) and digital transformation strategies, remote I/O systems have become a critical technology for connecting sensors, actuators, and monitoring devices to central control systems. These systems eliminate the need for extensive point-to-point wiring, consolidating field connections over a single network link and power supply.
This architecture reduces installation labor, lowers material consumption, shrinks control panel space, and increases system scalability. It is used in a wide range of applications, from discrete manufacturing to logistics automation, process industries to building automation.
βοΈ Unlimited Integration with Multi-Protocol Support
One of the most striking features of the iO-GRID X platform is its support for multiple industrial Ethernet protocols operating at data rates up to 100 Mbps. Popular communication interfaces such as EtherCAT, EtherNet/IP, PROFINET, Modbus TCP, and CC-Link IE Field Basic are available.
This broad protocol compatibility allows machine builders and system integrators to use a common hardware platform across different automation environments and customer specifications. Each fieldbus coupler includes two RJ45 Ethernet ports and an integrated two-port switch, enabling daisy-chain network topologies, simplifying installation and network expansion.
Integrated LED diagnostics indicate operational status, while firmware updates can be performed via a standard USB Type-C interface. These features support lifecycle maintenance and system upgrades without requiring specialized hardware.
π§ Flexible Modular I/O Architecture
The iO-GRID X family includes over 20 module types designed to meet varying signal requirements and channel densities. The modular structure allows users to combine digital, analog, and special modules within a single station.
[]Digital I/O Modules: Available in 16 and 32-channel configurations, with both sink and source options. Connection methods such as push-in terminals and 34-pin IDC connectors offer flexibility based on installation requirements.
[]Analog Modules: Four or eight channels, supporting voltage and current signals with 12 to 16-bit resolution. High-resolution analog processing enhances measurement accuracy in applications such as process monitoring, environmental control, and machine diagnostics.
- Special Modules: Options such as resistance temperature device (RTD) interfaces, thermocouple inputs, serial communication interfaces, high-speed counter modules, and pulse output modules support advanced automation functions like temperature monitoring, motion control, and encoder processing.
π‘οΈ Industrial Reliability and Maintenance Efficiency
Modules are designed to operate in ambient temperature ranges from -10Β°C to +60Β°C, supporting deployment in a wide variety of industrial environments. DIN rail mounting provides both mechanical stability and grounding continuity, while gold-plated spring inter-connection contacts ensure reliable communication between adjacent modules.
The platform operates using standard 24 VDC power supplies and is offered with two power supply configurations to support different station sizes and I/O densities. All models are CE and UL certified, supporting distribution in international and North American industrial markets.
Ease of maintenance is also a key design consideration. Detachable terminal blocks allow modules to be replaced without disconnecting field wiring, reducing downtime during service activities. Push-in wiring technology eliminates the need for tools during installation, while IDC connectors offer high-density wiring options for applications with higher channel counts.
π Supporting Smart Factory Infrastructure
The increasing adoption of connected manufacturing environments requires automation hardware that can integrate different devices and adapt to future requirements. By combining multi-protocol communication support with a configurable modular I/O architecture, the iO-GRID X platform aims to simplify the deployment of digital supply chain and industrial automation systems.
Daudin also offers customization services for hardware, firmware, software, labeling, and application-specific development. These capabilities enable machine builders and system integrators to tailor remote I/O solutions to specific operational requirements while maintaining compatibility with broader industrial control architectures.
In summary, Daudin's iO-GRID X platform is a significant step forward in industrial connectivity and digitalization. With its flexibility, extensive protocol support, and modular structure, it is poised to form the core infrastructure of smart factories and connected industrial operations.
