Economical Two-Axis Laser Scan Head from Aerotech
    ## Economical Two-Axis Laser Scan Head from Aerotech
    Aerotech offers an economical and high-performance solution to its family of two-axis laser scan heads with the new AGV-CPO CORE model. This product provides high precision and flexibility in laser micromachining applications.
    The AGV-CPO CORE is designed as an entry point to Aerotech's two-axis laser scan head series. This model extends high-performance features to a wider range of applications, offering a user-friendly experience without increasing system integration costs, thanks to its common control hardware.
    ### AGV-CPO CORE Features
    • Two-axis laser scan head provides high precision and stability
    • Utilizes a control system compatible with Aerotech's AGV family
    • Synchronization capability for up to 32 servo and galvo axes with the Automation1 programming platform
    • Easy integration with most CAM software thanks to RS-274 compatible G-code support
    • 22-bit effective resolution and micrometer-level accuracy
    • Integrated motor water cooling and optional air-cooled scan mirrors
    • Motor dynamics optimized for high-speed laser processing
    • Infinite field of view (IFOV) support for compatibility with rotary and linear servo systems
    • Position-synchronized output for constant energy distribution during speed and acceleration changes
    The AGV-CPO caters to a wide range of applications, from ultrafast laser applications to medical device manufacturing, electronics cutting, PCB drilling, and semiconductor processing applications. It also supports additive manufacturing techniques such as two-photon polymerization, offering flexible and scalable solutions.
    With the AGV-CPO CORE, Aerotech makes high-performance laser scanning technology more accessible while allowing users to seamlessly upgrade to meet increasing performance requirements. This makes it an ideal entry-level alternative for those seeking a simple and effective laser scanning solution for their manufacturing processes.
