zedmuhendislik
All About Transformers: Working Principle, Types, and Application Areas
Source: ZED Engineering1. Introduction
Electrical energy travels long distances from its point of generation to its point of consumption. In this process, the voltage level is crucial for the efficient and safe transmission of energy. This is where transformers come into play.Transformers are devices based on the principle of electromagnetic induction, used to step up or step down the voltage of alternating current (AC).
2. What is a Transformer?
A transformer is a device consisting of two or more windings, which are not in electrical contact but are magnetically linked. Its main function is to keep the power (VA) amount almost constant while transforming the voltage.Mathematically, it is expressed as:
V1/V2=N1/N2V_1 / V_2 = N_1 / N_2V1/V2=N1/N2 I1/I2=N2/N1I_1 / I_2 = N_2 / N_1I1/I2=N2/N1
Where:
- V1,V2V_1, V_2V1,V2: Primary and secondary voltages
- N1,N2N_1, N_2N1,N2: Number of turns in primary and secondary windings
- I1,I2I_1, I_2I1,I2: Represents primary and secondary currents.
3. Transformer Working Principle
The working principle of transformers is based on Faraday's Law of Electromagnetic Induction.This law states that "a time-varying magnetic flux creates an electromotive force (EMF) in a conductor."
Basic steps:
- AC voltage is applied to the primary winding.
- This voltage creates a varying magnetic flux (Φ) through the core.
- This flux induces a voltage (E₂) in the secondary winding.
- When a load is connected to the secondary terminals, current flow begins.
4. Types of Transformers
4.1. By Voltage Level
- Step-Up Transformer: Converts low voltage to high voltage.
→ Example: For power transmission lines in power plants. - Step-Down Transformer: Converts high voltage to low voltage.
→ Example: In transformer substations to supply power to city grids.
4.2. By Purpose of Use
- Power transformer: Used in electricity transmission and distribution.
- Distribution transformer: To supply power to buildings and facilities.
- Instrument transformer: Provides safe conversion for current and voltage measurements.
- Isolation transformer: Used for electrical isolation.
- Autotransformers (variacs): Provide adjustable voltage.
4.3. By Cooling Type
- Dry-type transformer: Cooled by air, preferred for indoor use.
- Oil-immersed transformer: Cooled by transformer oil, generally found outdoors.
5. Transformer Structure and Components
5.1. Core (Magnetic Core)
Carries the magnetic flux. It is usually made of silicon steel sheets and is laminated to reduce losses.5.2. Windings
- Primary winding: The winding to which the mains voltage is applied.
- Secondary winding: The winding from which the voltage is taken.
Wound with copper or aluminum conductors.
5.3. Oil (Transformer Oil)
Used to dissipate heat and provide electrical insulation.5.4. Casing and Accessories
Consists of components such as oil tank, conservator, Buchholz relay, temperature indicators, connection terminals, etc.6. Transformer Losses
Transformers are not ideal; there are two main types of losses:| Type of Loss | Description |
| Iron losses | Hysteresis and eddy current losses occurring in the core. Dependent on voltage. |
| Copper losses | Losses converted to heat due to resistance in the windings. Dependent on current. |
η=C\cıkıs\cGu¨cu¨Giris\cGu¨cu¨×100\eta = \frac{Çıkış Gücü}{Giriş Gücü} \times 100η=Giris\cGu¨cu¨C\cıkıs\cGu¨cu¨×100
In modern transformers, efficiency is above 98%.
7. Transformer Tests and Maintenance
Transformers undergo regular tests for safe and long-lasting operation:- Insulation resistance test (megger test)
- Turns Ratio Test
- Oil dielectric tests
- Voltage regulation measurements under load
8. Applications of Transformers
- Power plants
- Distribution centers
- Industrial facilities
- Hospitals and office buildings
- Renewable energy systems (solar, wind)
- Electronic devices (charging adapters, audio systems, etc.)
9. Future of Transformers: Smart and Digital Transformers
Thanks to new generation "Smart Transformer" technologies:- Remote monitoring (IoT-based)
- Load imbalance detection
- Automatic warning system with temperature and humidity sensors
- Energy efficiency analysis
Such features provide a safer and more sustainable energy infrastructure.
10. Conclusion
Transformers are the backbone of modern electrical energy systems.Correct transformer selection, along with regular maintenance and monitoring systems, is of great importance for both energy efficiency and system safety.
As ZED Engineering, we continue to develop highly efficient and safe transformer solutions in energy infrastructures.
📘 Source:
This article was prepared by the technical team of ZED Engineering.
All rights reserved.
