Diğer 5 Essential Steps for PLC Programming: A Comprehensive Guide for Beginners
Elif Özaksu
  • Altanlar
  • 1749391212429.webp​
    The Programmable Logic Controller (PLC) is one of the cornerstones of industrial automation.​
    For those who want to learn PLC programming, we have prepared a step-by-step, practical guide that can rank high on Google. Here are 5 essential steps to start PLC programming!​
    1. Choosing the Right PLC Equipment​
    Before you start PLC programming, you need to choose the right hardware and software.
    Which PLC Brand?​
    • Siemens (S7-1200, S7-1500) → Common for industrial applications
    • Allen-Bradley (MicroLogix, CompactLogix) → Popular in the US market
    • Mitsubishi (FX Series) → Affordable and user-friendly
    • Delta, Omron, Schneider → Alternatives suitable for different budgets
      Required Software
    • TIA Portal (Siemens)
    • RSLogix / Studio 5000 (Allen-Bradley)
    • GX Works (Mitsubishi)
    • Codesys (Multi-brand support)
    2. Learning Basic Ladder Diagram (LD) Logic​
    PLC programming begins with ladder diagrams. Its structure, similar to electrical schematics, makes it easy to understand.
    Basic Commands:​
    • NO (Normally Open) Contact → XIC (Examine If Closed)
    • NC (Normally Closed) Contact → XIO (Examine If Open)
    • Output (Coil) → OTE (Output Energize)
    Example Simple Program:​
    Code:
    | BUTON SENSOR MOTOR |
    • If BUTTON (NO contact) and SENSOR (NO contact) are active, the MOTOR runs.
    💡 Practical Tip: You can practice in a virtual environment with PLC simulator programs.
    3. Connecting the PLC to the Computer and Uploading the First Program​
    To program a PLC, you need the correct communication protocol and connection settings.
    Step-by-Step Connection:​
    1. Connect the PLC to the computer with a USB/RS485/Ethernet cable.
    2. Set the COM port settings correctly in the software.
    3. Put the PLC into online mode.
    4. Upload and test the program.
    ⚠ Attention! Incorrect settings will prevent communication with the PLC. Check the communication parameters in the manual.
    4. Using Timers, Counters, and Data Blocks​
    For real applications, timers, counters, and memory blocks are essential.
    Timer Usage:​
    • TON (Timer On Delay) → Provides output after a specific time.
    • TOF (Timer Off Delay) → Turns off the output after the signal is cut.
    Counter Usage:​
    • CTU (Count Up) → Up counter
    • CTD (Count Down) → Down counter
    Example Application:​
    Code:
    |----[ ]---------[TON T1 5s]----( )---|
    |   BUTON      (5 saniye sonra)   LED   |
    • If the BUTTON is held down, the LED turns on after 5 seconds.
    5. Debugging and Real-World Applications​
    PLC programs are prone to errors. If it's not working correctly:
    Debugging Techniques:​
    1. Online Monitoring → Monitor the program in real-time.
    2. Watch Table → Track variable values.
    3. Force Function → Manually trigger inputs/outputs.
    Real-Life Project:​
    • When the sensor detects material, the motor should run.
    • After 5 products pass, the conveyor belt should stop.
    • The counter should reset with the reset button.
    Conclusion: Advice for Those Who Want to Learn PLC Programming​
    ✔ Practice with free PLC simulators.
    ✔ Review Siemens and Allen-Bradley training documents.
    ✔ Share your questions on the Endüstri Vadisi Forum!
