🔍 Innovative Production Solution from Bertram Elektrotechnik
Bertram Elektrotechnik GmbH has developed a fully automated system for the production of solenoid valve armatures. This system integrates assembly, inspection, and packaging into a single process. MVTec HALCON machine vision software supports all processes, from barcode reading to position and presence checks, and even the final 3D quality inspection.
⚙️ Revolutionizing Automation and Quality Control
Founded in 1949 and based in Germany, Bertram is a company specializing in automation technology, control panel construction, and machine vision. They particularly focus on automated assembly machines with integrated testing technology. This new system, developed for a plant engineering customer, aims to increase the production capacity and significantly improve the quality control of armatures previously produced on a separate, slower assembly machine and randomly inspected manually.
🔄 Precise Assembly on a Rotary Table
Each armature is approximately 8-9 mm in diameter and 20-25 mm high, consisting of six components. The system operates in two lanes, producing two armatures every cycle in approximately seven seconds. A SCARA robot places raw parts into a tray and transfers them to a rotary indexing table. This table moves the parts through processing stations where small sealing inserts, small springs, and rivets are assembled. After checking for rivet presence, the large spring is assembled and inspected. In the final assembly station, large sealing inserts are placed into an oiled press-fit seat and pressed in using an assembly plug. A second SCARA robot transfers the armatures to the optical inspection station. Unsuitable parts are discarded into a separate drawer, while suitable parts are placed into blister packaging and removed from the system in stacks of four. According to Managing Director Jendrik Bertram, the combination of very small components, delicate sealing inserts and springs, precise assembly, and short cycle time would not be economically possible without machine vision.
🔬 Sub-Micron Precision Inspection
Quality inspection is performed using two Heliotis white light interferometers. A gripping and rotating module rotates each armature by 180 degrees, allowing both sides to be inspected. The system verifies the press-fit depth of the sealing inserts, the dimensional accuracy of the armatures, and the surface quality of the sealing inserts with sub-micron precision. Jendrik Bertram explains that conventional sensor technology was insufficient because dimensional accuracy and surface defects needed to be inspected on two different materials (steel and rubber), across the entire surface, contact-free, on both sides, and within the cycle time. This technology also enables 100% inspection, traceable measurement values, and visualization of defect patterns supporting serial defect detection and trend analysis.
💻 Multiple Tasks on a Single Software Platform
HALCON performs three key tasks in the system: reading barcodes on trays for component traceability, checking the position and presence of components at assembly stations using shape matching, and performing the final optical inspection. During this inspection, 3D height data from the two Heliotis sensors is analyzed directly using 3D operators in HALCON to select relevant 3D points, segment object models, calculate distances, combine 3D data, and perform coordinate transformations. Most inspections, including press-fit depth, dimensional accuracy, and surface features, are performed directly on the 3D data. Bertram creates the machine vision tasks in HDevelop, MVTec's integrated development environment, and integrates them into the runtime. Communication with the Siemens PLC occurs via OPC UA, and the interface is automatically generated from the procedure parameters of the HALCON jobs. Image acquisition, evaluation, and feedback to the PLC operate synchronously with the rotary indexing table. MVTec HALCON Product Manager Jan Gärtner states that this application demonstrates how standard software can cover identification, localization, presence control, 3D measurement, and surface inspection within a single system.
📈 Production Results Achieved
The system has been commissioned by the end customer and has since been expanded to include additional product variants. Production capacity has increased, and quality inspection has improved; the system operates within the required cycle time and provides traceable, in-line 100% inspection. Jendrik Bertram anticipates that as tasks become more challenging, the number of variants increases, and customers expect complete inspection directly on the production line, the importance of machine vision in special machine construction will continue to grow.
