✨ High Dynamism and Cybersecurity Combined
Baumüller has introduced its new generation of controllers, offering short cycle times and top-level cybersecurity for highly dynamic machine concepts: the b maXX controllerPLC and the b maXX drivePLC.
🧠 b maXX controllerPLC: Powerful and Flexible
This compact controller combines PLC functionalities with high processing power and open communication protocols. Meeting cybersecurity requirements and offering a cost-effective solution, the b maXX controllerPLC operates with a new Linux-based runtime system developed by Baumüller. This architecture provides an ideal environment for customer projects thanks to flexible expansion options, fast support, and modern programming methods.
🌐 Open Communication and Network Integration
For the integration of machine modules into existing plant networks, the b maXX controllerPLC supports standard interfaces and protocols such as OPC UA, MQTT, EtherCAT, and Ethernet. Optionally, digital/analog inputs, CANopen, and RS485 interfaces are also offered, ensuring maximum flexibility.
⚡ b maXX drivePLC: Drive-Integrated Motion Control
Developed to be fully compatible with the b maXX controllerPLC, the b maXX drivePLC performs complex motion control and technology functions directly in the drive. This achieves cycle times as low as 250 microseconds, ensuring faster responses and higher efficiency. Baumüller's comprehensive technology libraries are available for both control concepts, enabling dynamic applications to be implemented quickly and easily.
💡 New Standards in Industrial Automation
The direct integration of IT-friendly protocols like OPC UA and MQTT into the PLC layer is a significant development in modern industrial automation. Deterministic cycle times in the 250-microsecond range are critical for precise applications such as multi-axis handling, textile machinery, and high-speed packaging. Furthermore, automation providers are increasingly adopting Linux-based architectures to support compliance with industrial cybersecurity standards like IEC 62443.
