MV Operation Responsibility
Asım Aksu
What is High Voltage (HV) Operational Responsibility?​
High voltage (HV) facilities are electrical installations that include transformers, switchgear, circuit breakers, disconnectors, protection equipment, and power transmission-distribution components, and whose operation requires special technical knowledge and expertise. HV operational responsibility service is carried out to ensure the safe and compliant operation of these facilities.
The main purpose of HV operational responsibility is to ensure the safety of life and property, reduce electrical risks, operate the facility reliably, and monitor necessary technical controls in high voltage facilities.
Who is the HV Operations Manager?​
The HV operations manager is an electrical engineer with the necessary competence under the relevant legislation. The operations manager monitors the operational safety of the high voltage facility, reports identified technical deficiencies to the operation, and ensures that necessary measures are taken.
Operational responsibility is not merely about drawing up a contract or document. The current status of the facility, protection systems, grounding installation, high voltage equipment, and operating conditions must be evaluated periodically.
What are the Duties of the HV Operations Manager?​
Within the scope of HV operational responsibility, depending on the characteristics of the facility, tasks such as:
  • Monitoring the general condition of transformers and high voltage facilities,
  • Checking HV cells, circuit breakers, disconnectors, and protection equipment,
  • Evaluating the grounding system and equipotential connections,
  • Ensuring that operational and maneuvering procedures are carried out safely,
  • Identifying equipment requiring maintenance, repair, or renewal,
  • Reporting non-conformities that pose electrical risks to the operation,
  • Checking measures to prevent unauthorized persons from accessing high voltage sections,
  • Checking necessary safety equipment and warning signs,
  • Monitoring operational records and necessary technical documentation
are carried out.
Why is Transformer Operational Responsibility Important?​
A fault that may occur in transformer centers does not only lead to power outages. Insulation problems, overheating, grounding faults, deficiencies in protection systems, or incorrect maneuvers can create serious risks to life and property safety.
Therefore, transformer operational responsibility aims for the safe and sustainable operation of the facility beyond merely keeping it operational.
Through regular technical monitoring, it is possible to detect potential fault conditions at an early stage, plan necessary maintenance and repairs, and reduce unexpected power outages.
In Which Facilities is HV Operational Responsibility Required?​
HV operational responsibility is important in businesses that have their own transformer center or high voltage facility. In this context;
factories, industrial facilities, hotels, hospitals, shopping malls, production facilities, large commercial buildings, warehouses, and businesses that receive energy from a private transformer are among the facilities that need to be evaluated in terms of high voltage operational safety.
The obligations to be applied should also be evaluated separately according to the facility's connection type, voltage level, transformer power, and operational characteristics.
Are HV Operational Responsibility and Transformer Maintenance the Same Thing?​
HV operational responsibility and transformer maintenance are different services.
HV operational responsibility is an engineering service aimed at the safe operation of the high voltage facility, monitoring its technical condition, and determining necessary measures.
Transformer and HV maintenance services, on the other hand, cover applications such as maintenance, cleaning, testing, measurement, and, if necessary, part replacement carried out on transformers, cells, circuit breakers, connection points, and other high voltage equipment.
These two works complement each other. Timely execution of maintenance and control needs determined within the scope of operational responsibility is important for facility reliability.
Grounding and Protection Systems in HV Facilities​
In high voltage facilities, the grounding system is one of the most important elements of electrical safety. Proper grounding of the transformer center, cells, metal enclosures, and other conductive parts; fault condition
