🤔 Why AI Pilots Don't Scale
Many manufacturers find that while AI delivers great results in pilot projects, it struggles to scale. Gains remain localized and cannot be transferred from one plant to another. This is because AI is approached as a new set of tools.
💡 What is Systemic AI?
According to Accenture's findings, leading companies are moving towards "systemic AI." This means AI functions as the manufacturing system itself, integrating decision-making processes across machines, lines, plants, and supply networks with physical execution.
Unlike previous Industry 4.0 programs, systemic AI connects key performance indicators, decision-making authorities, and escalation paths. This allows the system to act consistently and securely across different plants without being built from scratch each time.
🏆 Systemic AI Creates Lasting Advantages
Most AI projects are done in operations and maintenance, for example, to reduce quality defect rates. But what if these defects never occurred? What if the production line or the entire plant was virtually designed and commissioned, and optimized before construction began?
Such "upstream" gains are one of the biggest advantages of systemic AI. AI applied early in asset and product development lifecycles secures cost and performance before capital is committed. Errors are caught without teams having to rework physical assets, and time to market for products is shortened.
Manufacturers using systemic AI report significant efficiency gains. A US aerospace manufacturer saw that using AI in the transition from engineering BOM to manufacturing BOM eliminated traceability errors that previously propagated unchecked into production.
More broadly, companies report a 30-40% reduction in unplanned downtime, a 25-30% increase in maintenance capacity, and over 30% acceleration in new product introductions.
🚀 Moving from Pilot AI to Systemic AI
The five areas that support systemic AI are:
- Integrate Systems and Data: Ensure decisions flow end-to-end. Manufacturing systems are often optimized locally. Planning relies on forecasts, production reacts on the shop floor, quality detects issues later, and logistics compensates afterwards. Manufacturers must connect these functions and systems so that decisions reinforce each other in real-time. This means addressing the most challenging problem in manufacturing IT: connecting enterprise systems (planning, finance, supply) with operational systems (machines, sensors, quality) and engineering systems (product specifications, change management, BOM). A practical approach is to create a shared semantic layer. With common definitions, AI can reason across systems and act consistently.
- Know What's Worth Building Yourself: Foundation models and industrial AI platforms have made it impractical to build everything from scratch. Manufacturers should focus on what differentiates them: domain expertise, process knowledge, proprietary data, and integration architecture. Some assumed that generative AI and "vibe coding" would make it possible to build complex systems like MES and ERP without expert help. The experiment failed. One executive put it this way: "Maybe some companies will try it. Good luck. It's much more complex than people expect." As a result, the need for partners and providers has increased. However, no single provider offers the full stack. Manufacturers should look for deep domain expertise and a track record of IT/OT integration. No vendor's product works out-of-the-box without deep integration expertise.
- Redesign Decision-Making Authorities and Operating Rhythms: AI deployments often stall because organizations fail to anticipate how employees will experience AI and adapt their decision-making accordingly. Before AI is deployed, manufacturers must define which decisions can be automated, which require human validation, and which conditions trigger escalation. Operating rhythms determine whether AI is truly used. Leading manufacturers integrate AI into daily workflows. For example, shift handovers refer to AI-generated insights, and planning reviews are built around live model outputs. In this way, AI ceases to be an option and becomes part of the job.
- Create Secure Closed Loops with Physical AI and Agent AI: Physical AI excels at execution, while agent AI excels at coordination. Together, they form a closed-loop system that enables the factory to anticipate, adapt, and continuously improve. To achieve this, AI outputs must directly influence machines and workflows. Digital twins and simulations act as safety layers before real-world applications. As agent logic spreads into operational environments, cybersecurity risks increase. Manufacturers must segment IT and OT networks, implement strict validation for all connections, monitor anomalies in real-time, and maintain incident response plans that account for physical security. AI systems must also clearly define the boundaries of their authority over critical production decisions.
- Keep Humans in Leadership: Autonomy without accountability is a meaningless risk. Manufacturers who make the most progress with AI clearly define where human judgment is necessary. To scale safely, companies must formalize four modes of control:
Autonomous execution within safeguards (system acts when risk is low and defined constraints are met)
- Human validation required (supervisor approves proposed action before execution)
- Escalation required (thresholds trigger escalation to a designated role)
- Stop and revert for anomalies (anomalies automatically trigger reversion to manual control)
