Elif Özaksu
🌟 The Future of Robots: Brain or Body?
When we think of robots, we immediately imagine human-like machines such as C-3PO, capable of walking, grasping objects, and understanding human language. In the past, it was thought that robots needed smarter brains. However, while brain development is rapidly advancing today, the main challenges have shifted to the robot's physical capabilities, namely dexterity, reliability, and the data problem.
This situation is evident in every field where artificial intelligence is used, such as drones, autonomous vehicles, and factory automation. Machines that bear no resemblance to C-3PO are already achieving valuable work on a large scale precisely because they avoid being general-purpose.
🧠 Brain Develops Rapidly, Body Lags Behind
The reasoning capabilities of robots have advanced far beyond what most people realize. Modern visual-language-action models (VLAs) enable robots to understand what they see and act accordingly. For example, Google DeepMind's Gemini Robotics 1.5 model is separated into a "reasoning" model that performs spatial understanding and multi-step planning, and an "action" model that issues motor commands.
This separation tells us a lot: labs release the part they trust and hold back the part they don't. While reasoning is not yet perfect, it is no longer the biggest obstacle for robots. Even researchers are no longer investing in the reasoning gap. The real problem is having a body that can translate this intelligence into action with the right precision and consistency, and learn from the data generated by these actions.
🖐️ Dexterity Is Not Yet Sufficient
Human hands have over 20 degrees of freedom, and coordinating contact-rich manipulation in such a complex structure is still an unsolved problem for manufacturing reliability. Most real-world applications still operate with simple parallel-jaw grippers. In-hand manipulations, such as re-positioning an object within a grasp, remain a challenge to be solved.
Learned policies that reliably pick objects can fail in contact-rich tasks like standing a cup upright or stacking objects. The bottleneck here is not just the control policy, but also the hardware: tendon-driven multi-fingered hands break easily and are difficult to calibrate.
✅ Reliability Is an Undisputable Requirement
Even if hands were good enough, it's not capability but reliability that prevents deployment. A policy with an 80% success rate can make for a great demo video. But a warehouse or operating room needs reliability measured in "nines" over millions of cycles, including awkward edge cases. The difference between "it works in the demo" and "it works unsupervised on the night shift" accounts for a huge amount of engineering.
Surgery illustrates this clearly. A team from Johns Hopkins and Stanford trained a model on about 20 hours of video, enabling a da Vinci surgical robot to suture tissue and manipulate a needle.
The intelligence is there. Yet every da Vinci robot in clinical use remains at Level 0 autonomy; every movement is guided by a surgeon. Because failure is unacceptable on the operating table. In these critical situations, it's not intelligence but reliability that prevents deployment.
📊 No Shortcut for Data
Unlike dexterity and reliability, there's no internet-scale shortcut for data. Language models could leverage the internet; however, there's no equivalent dataset for robot actions. The solution to this problem is the "data pyramid": a small amount of real robot teleoperation at the top, a large layer of simulated and synthetic data in the middle, and web-scale human video at the bottom. The data scarcity is very clear: Physical Intelligence's π0.5 model gets 97.6% of its training data from sources other than the robot it's trying to control.
A second data problem emerges as soon as a machine is deployed: not training data, but operational data. Training data must be produced; operational data is a never-ending stream of data. While the internet trains the brain, reality trains the body.
The learning loop everyone relies on operates entirely on this data, but its infrastructure is far less mature than the models it feeds. Teams that treat telemetry as core infrastructure early in the process are the ones who don't have to rebuild it under load later.
🚀 Narrow-Scope Robots Are Already Working
When you constrain the task, every bottleneck above shrinks. This is seen everywhere a team has shipped something narrow enough to be reliable.
Warehouses took the first step in this regard. The lesson of 2025 was that reliability beats novelty. Fully autonomous picking across the entire SKU range is still unsolved to the point of replacing a human picker. But when you remove variability (grocery distribution, pallet handling, sortation), the same systems scaled faster than almost anyone predicted.
Inspection used the same shortcut on a different dimension. Boston Dynamics' thousands of Spot units patrol oil rigs, nuclear facilities, and factories, each replacing hundreds of static sensors. In April 2026, Gemini Robotics-ER 1.6 integrated into Spot's inspection software. But the discipline was maintained; when conditions worsened, Spot stopped, documented the obstacle, and sent a notification to a human instead of guessing.
Even the best-funded general-purpose companies prove this point. Skild AI raised nearly $1.4 billion to build a single brain for any robot, but early revenue comes almost entirely from narrow deployments: security, inspection, warehouses, and construction.
While the vision is general-purpose, the revenue is single-purpose.
🛠️ Build for the Robot You Have
C-3PO is coming, but not first, and not soon. The current answer is a capable mind riding a narrow, reliable body. The robots we're truly ready for are already flying over our neighborhoods, managing our distribution centers, and reading gauges in places humans prefer to avoid.
General-purpose robotics is the future. The real question is what you build while you wait.
