Alper AktaÅŸ
💡 Physics and AI: The New Face of Industrial Software
A significant realization is occurring in the world of industrial software engineering: while general large language models understand sentences, they lack an inherent grasp of thermodynamics, kinematics, or manufacturing geometry. To create real value, neural networks must be anchored within the strict boundaries of the physical sciences. This transforms the digital twin from a passive record-keeping system into an active, managed foundry for human-agent collaboration.
In this new paradigm, generative architectures are used as high-speed pre-acceleration filters. Instead of engineering teams spending weeks manually testing infinite permutations within a design space, generative models step in to narrow and compress millions of options down to a few high-probability candidates.
These candidates are then fed into high-fidelity, deterministic physical simulation models for absolute mathematical validation. The generative brain creates the concept, while the deterministic twin enforces physical reality.
💸 Eliminating the "Data Tax"
The highest cost factor in any advanced industrial data initiative used to be the manual data engineering tax; that is, the tedious and repetitive processes of extracting tag streams from disparate plant histories and manually mapping them to asset descriptions.
Advanced software orchestration environments (such as Siemens' Intelligence Center X) target this bottleneck by functioning as automated knowledge graph generation engines. The core breakthrough is the introduction of out-of-the-box, pre-populated industrial ontologies directly embedded into the core platform's semantic middleware layer. These data models pre-code industrial logic across disparate operational domains by naturally structuring ingestion streams into shared lifecycle intelligence:
[]Siemens Designcenter X and Teamcenter X ontologies: Pre-populated with engineering lifecycle semantics, understanding precise relational attributes between 3D CAD topologies, bills of materials, geometric configurations, material data sheets, and engineering material lists.
[]Siemens Opcenter X ontologies: Pre-populated with manufacturing operations semantics, mapping real-time station routings, production logs, quality tolerances, machine tool paths, and standardized equipment failure signature models.
Because these ontologies are pre-coded with industrial context, incoming autonomous execution agents don't need to spend cycles "learning" how a factory data model is organized. By connecting to a pre-structured representation of physical reality, it allows an agent to cross-reference a real-time edge telemetry anomaly directly to the original CAD design specification or material log without human intervention.
This scale has already been validated in the field; global pharmaceutical innovator GlaxoSmithKline is running a live industrial ontology graph of 15 billion nodes within Intelligence Center X, synchronizing real-time process visibility and regulatory compliance context across its global plant footprint.
🚫 Debunking the Claude Code Fallacy
A common narrative currently echoing in Silicon Valley's hype cycle claims that traditional low-code platforms are obsolete because advanced, autonomous coding agents (like Anthropic's Claude Code) can automatically generate raw scripts, structure databases, and build microservices from natural language prompts.
This belief reveals a profound misunderstanding of how software governance operates in high-stakes industrial environments.
In an office productivity setting, you might allow a probabilistic AI agent to write and execute code on the fly. On a manufacturing plant floor or within a chemical process network, you cannot allow an AI model to push unvalidated code scripts directly to operational databases, SCADA networks, or edge controllers.
Low-code platforms (like Mendix) do not serve as drag-and-drop tools that help business users avoid writing code syntax, but rather as the mandatory structural body, application state coordinator, and deterministic governance container for autonomous AI agents.
The architectural division of labor is rigid: the underlying AI model functions as the brain, but the low-code framework functions as the physical body and the legal boundary. The agent operates strictly within the low-code container, ensuring that all automated code outputs are sandboxed, audited, and structurally prevented from exceeding safe operational parameters.
Vivix Vidros Planos, Brazil's leading flat glass manufacturer, leveraged this architecture by building approximately 30 different Mendix applications that unify data layers between their SAP S/4HANA ERP core, industrial edge nodes, and a central Snowflake data warehouse. When they deployed their AI-powered virtual assistants, they used the low-code platform as the secure application interface to govern the agent's actions, achieving an 85% reduction in manufacturing problem-solving latency while capturing 6,000 hours of manual labor in a single operational year.
🎯 Design Surrogates and Lifecycle Boundary Models
To maximize commercial value, executives need to look beyond unified marketing definitions to identify the sharp technical distinction in modern industrial codebases. Software portfolios are progressing along two entirely distinct, parallel algorithmic paths:
Path A: Customer-Specific Geometric Deep Learning Surrogates
Designed for high-speed physics approximation, this path transforms the passive CAD/PLM repository into an active predictive environment (like Siemens' Simcenter PhysicsAI), achieving 500 to 1,000 times simulation acceleration metrics.
This capability is not based on an off-the-shelf, generalized foundation model; it is strictly trained on a specific customer's own historical simulation data assets. To build a functional surrogate, an enterprise feeds thousands of its own historical, high-fidelity Computer-Aided Engineering (CAE) meshes into Graph Neural Networks (GNNs) for a specific product architecture (e.g., historical automotive chassis or aerospace wing designs).
Rigid factory floor control loop optimization can never operate through an open internet query framework. It requires edge-based orchestration.
The network acts as a localized neural shortcut that implicitly learns complex geometric and boundary relationships, completely removing traditional, iterative differential equation solving from the design cycle.
Path B: Industrial Foundation Model Initiative
Completely separate from localized design surrogates is the multi-year campaign to build the industry's true cross-domain Design-to-Manufacturing Boundary Model. It leverages large, global ecosystem datasets (such as 150 petabytes of data).
