πŸ€– CNC Vise Loading Automation in Low-Volume Production: An Innovative Solution from Tezmaksan πŸš€
    In low-volume, high-mix production environments, automation is critical for efficiency and flexibility. Tezmaksan stands out with its compact robotic automation system designed to overcome this challenge: CubeBOX Blues RT-VISE.
    This innovative system automates the processes of workpiece loading and positioning with vises in computer numerical control (CNC) machines, minimizing manual intervention in precision manufacturing, contract manufacturing, and custom part production sectors.
    βš™οΈ Robotic Architecture and Workpiece Clamping Operation​
    At the heart of the system is a 6-axis industrial robot integrated with a storage rotary table. This configuration manages the automatic loading and unloading of standard vises for up to two CNC machines. Operators can prepare multiple workpiece clamping configurations offline, reducing machine downtime associated with manual job changes.
    Thanks to the continuous availability of pre-prepared vises, the machine tool can maintain uninterrupted machining cycles even during unattended shifts.
    πŸ’‘ Hardware Compatibility and Kinematic Integration​
    The automation unit supports various vise types without the need for specialized robotic end-of-arm tooling integration for different raw material shapes. Control and sequencing are provided via an industrial computer and a robot controller running proprietary RoboCAM+ software.
    The software defines part coordinates and machining sequences using a graphical interface, eliminating the need for manual coordinate programming. The system directly converts computer-aided design (CAD) data into robot kinematics, shortening setup times during frequent production changes and ensuring consistent machining across different batches.
    πŸ“ Structural Footprint and Deployment Mechanics​
    The system has a modular design, intended to integrate into existing workshop layouts and limited floor space. The modularity of the robotic cell allows for configuration adjustments to suit specific machine tool alignments and standard interfaces.
    By automating the manipulation of the vise rather than relying on individual workpiece handling, the system increases production output and machine utilization rates in highly variable production batches.
    πŸ”¬ Technical Details and Industry Comparison​
    In the CNC automation sector, robotic vise loading systems operate on the principle of standardized zero-point clamping interfaces, allowing the industrial robot to transfer the entire workpiece clamping device instead of gripping the raw material. This approach is comparable to flexible manufacturing systems (FMS) and automated pallet changers from providers like Halter CNC Automation and Fastems.
    While high-volume automation relies on specialized robotic grippers handling specific workpiece blanks, vise loading standardizes the physical interface between the robot and the machine tool table. The comparison of these systems is based on the payload capacity, which determines the combined weight of the vise and workpiece, and the spatial density of the storage table.
    Such systems typically support an automated payload capacity of 15 to 35 kilograms and require integration with automatic pneumatic or hydraulic zero-point clamping mechanisms within the CNC machine bed for mechanical securing of the vise during heavy milling operations.
    Tezmaksan's CubeBOX Blues RT-VISE solution combines the efficiency and flexibility brought by automation in low-volume, high-mix production scenarios, offering significant advantages to businesses in the competitive environment of modern manufacturing.
