Electronic devices operating in industrial environments can both generate electromagnetic interference (EMI) and be affected by EMI from other devices. This can impact not only device performance but also the reliability of the entire system.
So, what are EMC/EMI, why are they so critical, and how do we protect against them?
👉 You can share your experiences and suggestions in this thread.
👉 A very valuable knowledge base can be formed for anyone involved in device design, fault analysis, or product certification processes.
🧠 Brief Definition:
- EMI (Electromagnetic Interference): When one device electromagnetically affects other devices.
- EMC (Electromagnetic Compatibility): The state where a device neither generates EMI nor is susceptible to external EMI.
🛡️ EMC/EMI Protection Methods:
- Cabling Techniques:
- Separation of signal and power cables
- Use of twisted pair cables
- Cable shielding
- Correct placement of grounding points
- Filtering:
- EMI filters (line filters) for noise suppression at input and output
- Ferrite beads and inductors to block high-frequency interference
- Encapsulation and Enclosure:
- Preventing interference propagation with metal enclosures
- Using a "ground plane" in PCB design
- Faraday cage applications
- EMC Rules in PCB Design:
- Separation of analog and digital signals
- Control of return currents
- Keeping high-frequency traces short
- Correct grounding strategies in multi-layer PCBs
- Grounding Strategies:
- Single-point or multi-point grounding
- Separation of chassis and earth ground and selection based on application
🔍 EMC Tests in Industry:
- EMC tests are mandatory for products seeking CE certification.
- Tests are performed using tools such as anechoic chambers, EMI test equipment, and spectrum analyzers.
- Compliance with standards like EN 61000-6-x is required, especially for the European market.
💬 Let's Discuss:
- What do you think is the most common EMI problem encountered in the field?
- Where do you think the weakest link is in terms of EMC?
- What effective filter brands do you use?
